incoming calls from TELCO fail via my E1 line
m.gnahoui
Hi Cisco community,
I have a problem with calls coming from outside via my E1 line.
Outgoing calls from my network go through while incoming calls fail.
TELCO (E1 with SDAs) --> CUBE (ISR 4331) --> CUCM (version 12.5)
I tried to contact the TELCO but they told me no problem on their side. Is the error level? Help me please. I can't identify the problem.
When I examine, I manage to see at the debug isdn level, **error**: l3_badpeermsg and the debug voip ccapi Disconnect Cause=102.
Attached are the debug files and my full configuration
Any feedback/guidance you can provide would be greatly appreciated
You have to check the CUCM logs to dig deeper.
The issue can be a lot of things.
The working call from CUCM to CUBE uses TCP.
But the non-working call from CUBE to CUCM uses UDP. Maybe you should configure the dial-peer to use TCP too.
"session transport tcp"
6 Replies 6
b.winter
Can you post the output of the following debugs:
debug isdn q931
debug ccsip messages
debug voice translation
debug voice ccapi ind 1
debug voice ccapi ind 2
debug voice ccapi ind 74
m.gnahoui
Hi @b.winter , see below.
The IP-address 10.205.0.21 (CUCM ?) is not responding to the INVITE and therefore, CUBE resends the INVITE mulitple times.
Since after a certain amount of time the PSTN provider doesn't receive anything back from CUBE, the provider hangs up the call
m.gnahoui
CUCM is 10.205.0.21. What could be the cause and how to fix it ? Outgoing calls work well though.
Thank you so much. I was able to solve it by adding this :
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
And I applied the "session transport tcp" and "voice-class codec 1" to all dial-peer voice XXX voip
dial-peer voice 121 voip
corlist outgoing APPEL-INTERNE
description description PHONE USER 1...
destination-pattern 1...
session protocol sipv2
session target ipv4:10.205.0.21
dtmf-relay rtp-nte sip-kpml sip-notify
voice-class codec 1
no vad
