Incoming calls never goes to an extension
Hello there ,
I have an issue with the incoming calls made from outside to inside of the CUCM network.
I want to call the number 22XXXXXX 8 digit number and then to ring my internal extension 101
What i have done in the cube
voice translation-rule 100
rule 1 /22XXXXXX/ /101/
voice translation-profile 100
translate called 100
dial-peer voice 100 voip
translation-profile incoming 100
destination-pattern [2-9].......
session protocol sipv2
session target ipv4: *SIP Trunk IP*
incoming called-number [2-9].......
dtmf-relay rtp-nte
no vad
dial-peer voice 300 voip
destination-pattern 1..
session target ipv4:*CUCM IP*
dtmf-relay rtp-nte
no vad
The call is coming in but never goes to the extension with the cube at the end to send
sip/2.0 503 service unavailable
Do i have to do anything in the call manager ?
Thank you
13 Replies 13
pwenger
Level 3
Level 3
Hello
Is your SIP trunk between CUBE and CUCM up and running?
Do you see the INVITE going to CUCM when you debug (debug ccsip messages) on CUBE?
Can you ping CUCM and is there a firewall between CUBE and CUCM?
Hope this helps
Peter
Hello ,
Yes is up and running. I can make outbound calls.
Yes there is an INVITE and at the end there is a 503 service unavailable.
There is no firewall
ISP----ISR4451(Cube)----CUCM
Do i have to but the translation pattern that is in the cube , in to the call manager also ?
pwenger
Level 3
Level 3
When your INVITE sent to CUCM looks good, there will be no need for a translation pattern in CUCM.
Can you post the debug output please.
Check the calling search space for incoming calls on the SIP trunk in CUCM.
Is there a MTP allocated on SIP trunk and early offer is used? Always reset the trunk after configuration changes.
Peter
Here it is
037240: *Sep 27 12:26:52.697: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:22XXXXXX@10.249.49.90:5060 SIP/2.0
Max-Forwards: 17
Via: SIP/2.0/UDP 10.224.150.7:5060;branch=z9hG4bKg3Zqkv7ixcpxkn5w6lowc2sg844ipwtnm
To: "22XXXXXX 22XXXXXX" <sip:22XXXXXX@trunk.cyta.com.cy>;cscf
From: <sip:96xxxxxx@fmc.cyta.com.cy;user=phone>;tag=h7g4Esbg_2057284738-1569576469727-
Call-ID: BW122749727270919761414899@10.224.112.10
CSeq: 956703344 INVITE
Contact: <sip:sgc_c@10.224.150.7;transport=udp>
Record-Route: <sip:10.224.150.7;transport=udp;lr>
Min-Se: 600
P-Asserted-Identity: <sip:96XXXXXX@fmc.cyta.com.cy;user=phone>
Privacy: none
Session-Expires: 1800
Content-Type: application/sdp
Content-Length: 295
Allow: ACK, BYE, CANCEL, INFO, INVITE, OPTIONS, PRACK, REFER, NOTIFY, UPDATE
Accept: application/media_control+xml
Accept: application/sdp
Accept: application/x-broadworks-call-center+xml
Accept: message/cpim
Accept: multipart/mixed
v=0
o=BroadWorks 69962648 1 IN IP4 10.224.150.7
s=-
c=IN IP4 10.224.151.4
t=0 0
m=audio 6216 RTP/AVP 8 18 100
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:100 telephone-event/8000
a=fmtp:100 0-15
a=sqn: 0
a=cdsc: 1 image udptl t38
a=sendrecv
a=ptime:20
037241: *Sep 27 12:26:52.698: //-1/EBA8E6CD8772/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=96XXXXXX
----- ccCallInfo IE subfields -----
cisco-ani=96XXXXXX
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=22XXXXXX
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFFFFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
037242: *Sep 27 12:26:52.699: //-1/EBA8E6CD8772/CCAPI/cc_api_call_setup_ind_common:
Interface=0x7F76560DEB08, Call Info(
Calling Number=96XXXXXX,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=22XXXXXX(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=100, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=2236
037243: *Sep 27 12:26:52.699: //-1/EBA8E6CD8772/CCAPI/ccCheckClipClir:
In: Calling Number=96XXXXXX(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
037244: *Sep 27 12:26:52.699: //-1/EBA8E6CD8772/CCAPI/ccCheckClipClir:
Out: Calling Number=96XXXXXX(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
037245: *Sep 27 12:26:52.699: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
037246: *Sep 27 12:26:52.699: :cc_get_feature_vsa malloc success
037247: *Sep 27 12:26:52.699: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
037248: *Sep 27 12:26:52.699: cc_get_feature_vsa count is 1
037249: *Sep 27 12:26:52.699: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
037250: *Sep 27 12:26:52.699: :FEATURE_VSA attributes are: feature_name:0,feature_time:140146424549740,feature_id:603
037251: *Sep 27 12:26:52.699: //2236/EBA8E6CD8772/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=96XXXXXX(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=22XXXXXX(TON=Unknown, NPI=Unknown))
037252: *Sep 27 12:26:52.699: //2236/EBA8E6CD8772/CCAPI/cc_process_call_setup_ind:
Event=0x7F7661DC2BA0
037253: *Sep 27 12:26:52.699: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 22XXXXXX
037254: *Sep 27 12:26:52.699: //2236/EBA8E6CD8772/CCAPI/ccCallSetContext:
Context=0x7F7667D1E9E0
037255: *Sep 27 12:26:52.699: //2236/EBA8E6CD8772/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 2236 with tag 100 to app "_ManagedAppProcess_Default"
037256: *Sep 27 12:26:52.700: //2236/EBA8E6CD8772/CCAPI/ccCallProceeding:
037257: *Sep 27 12:26:52.700: //2236/EBA8E6CD8772/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=300, Params=0x7F7667D11B60, Progress Indication=NULL(0)
037258: *Sep 27 12:26:52.700: //2236/EBA8E6CD8772/CCAPI/ccCheckClipClir:
037259: *Sep 27 12:26:52.700: //2236/EBA8E6CD8772/CCAPI/ccCheckClipClir:
037260: *Sep 27 12:26:52.700: //2236/EBA8E6CD8772/CCAPI/ccCallSetupRequest:
Destination Pattern=1.., Called Number=101, Digit Strip=FALSE
037261: *Sep 27 12:26:52.700: //2236/EBA8E6CD8772/CCAPI/ccCallSetupRequest:
Called Number=101(TON=Unknown, NPI=Unknown),
Redirect Number=, Display Info=
Account Number=96XXXXXX, Final Destination Flag=TRUE,
Guid=EBA8E6CD-E058-11E9-8772-D6D506AEE7C8, Outgoing Dial-peer=300
037262: *Sep 27 12:26:52.700: //2236/EBA8E6CD8772/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-ani=96XXXXXX
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=101
cisco-desttype=0
cisco-destplan=0
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
037263: *Sep 27 12:26:52.701: //2236/EBA8E6CD8772/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x7F76560C7758, Interface Type=1, Destination=, Mode=0x0,
Call Params(Calling Number=96XXXXXX,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=101(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=300, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
037264: *Sep 27 12:26:52.701: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
037265: *Sep 27 12:26:52.701: :cc_get_feature_vsa malloc success
037266: *Sep 27 12:26:52.701: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
037267: *Sep 27 12:26:52.701: cc_get_feature_vsa count is 2
037268: *Sep 27 12:26:52.701: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
037269: *Sep 27 12:26:52.701: :FEATURE_VSA attributes are: feature_name:0,feature_time:140146424550188,feature_id:604
037270: *Sep 27 12:26:52.701: //2237/EBA8E6CD8772/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
037271: *Sep 27 12:26:52.701: //2237/EBA8E6CD8772/CCAPI/ccCallSetContext:
Context=0x7F7667D11AE0
037272: *Sep 27 12:26:52.701: //2236/EBA8E6CD8772/CCAPI/ccSaveDialpeerTag:
037273: *Sep 27 12:26:52.701: //2237/EBA8E6CD8772/CCAPI/ccGetMediaClassTag:
media class tag 0
037274: *Sep 27 12:26:52.701: //2237/EBA8E6CD8772/CCAPI/ccSetMediaclassIp2ipTags:
media class tags set: NR 0, ASP 0
037275: *Sep 27 12:26:52.701: //2236/EBA8E6CD8772/CCAPI/ccGetMediaClassTag:
media class tag 0
037276: *Sep 27 12:26:52.701: //2236/EBA8E6CD8772/CCAPI/ccSetMediaclassIp2ipTags:
037277: *Sep 27 12:26:52.702: //2237/EBA8E6CD8772/CCAPI/ccGet_xc_nr_asp_info:
media class tags: NR 0, ASP 0
037278: *Sep 27 12:26:52.702: //2236/EBA8E6CD8772/CCAPI/ccGet_xc_nr_asp_info:
037279: *Sep 27 12:26:52.702: //2236/EBA8E6CD8772/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
From: <sip:96XXXXXX@fmc.cyta.com.cy;user=phone>;tag=h7g4Esbg_2057284738-1569576469727-
Date: Fri, 27 Sep 2019 12:26:52 GMT
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-16.9.2
Session-ID: 00000000000000000000000000000000;remote=5c62a9ce0bb95866be792cc2c4c81303
Content-Length: 0
037280: *Sep 27 12:26:52.703: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 17
Via: SIP/2.0/UDP 10.224.150.7:5060;branch=z9hG4bKg3Zqkv7ipbfheb6ou3u61y2zoqnyuu48e
Min-Se: 600
Privacy: none
Content-Length: 297
v=0
s=-
c=IN IP4 10.224.149.68
t=0 0
m=audio 40148 RTP/AVP 8 18 100
a=fmtp:18 annexb=no
a=fmtp:100 0-15
a=sqn: 0
a=sendrecv
a=ptime:20
037281: *Sep 27 12:26:52.703: //2236/EBA8E6CD8772/CCAPI/cc_api_call_disconnected:
Cause Value=47, Interface=0x7F76560DEB08, Call Id=2236
037282: *Sep 27 12:26:52.703: //2236/EBA8E6CD8772/CCAPI/cc_api_call_disconnected:
Call Entry(Responsed=FALSE, Cause Value=47, Retry Count=0)
037283: *Sep 27 12:26:52.703: //2237/EBA8E6CD8772/CCAPI/ccCallDisconnect:
Cause Value=47, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
037284: *Sep 27 12:26:52.703: //2237/EBA8E6CD8772/CCAPI/ccCallDisconnect:
Cause Value=47, Call Entry(Responsed=FALSE, Cause Value=47)
037285: *Sep 27 12:26:52.703: //2237/EBA8E6CD8772/CCAPI/cc_api_get_transfer_info:
Transfer Number=NULL
037286: *Sep 27 12:26:52.704: //2236/EBA8E6CD8772/CCAPI/ccCallDisconnect:
Cause Value=47, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=47)
037287: *Sep 27 12:26:52.704: //2236/EBA8E6CD8772/CCAPI/ccCallDisconnect:
Cause Value=47, Call Entry(Responsed=TRUE, Cause Value=47)
037288: *Sep 27 12:26:52.704: //2236/EBA8E6CD8772/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7F76560DEB08, Tag=0x0, Call Id=2236,
Call Entry(Disconnect Cause=47, Voice Class Cause Code=0, Retry Count=0)
037289: *Sep 27 12:26:52.704: //2236/EBA8E6CD8772/CCAPI/cc_api_call_disconnect_done:
Call Disconnect Event Sent
037290: *Sep 27 12:26:52.704: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
037291: *Sep 27 12:26:52.704: :cc_free_feature_vsa freeing 7F7661DA1160
037292: *Sep 27 12:26:52.704: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
037293: *Sep 27 12:26:52.704: vsacount in free is 1
037294: *Sep 27 12:26:52.705: //2237/EBA8E6CD8772/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7F76560C7758, Tag=0x0, Call Id=2237,
037295: *Sep 27 12:26:52.705: //2237/EBA8E6CD8772/CCAPI/cc_api_call_disconnect_done:
037296: *Sep 27 12:26:52.705: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
037297: *Sep 27 12:26:52.705: :cc_free_feature_vsa freeing 7F7661DA1320
037298: *Sep 27 12:26:52.705: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
037299: *Sep 27 12:26:52.705: vsacount in free is 0
037300: *Sep 27 12:26:53.204: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 17
Min-Se: 600
Privacy: none
Content-Length: 297
v=0
s=-
t=0 0
a=fmtp:18 annexb=no
a=fmtp:100 0-15
a=sqn: 0
a=sendrecv
a=ptime:20
037301: *Sep 27 12:26:53.205: //-1/EBF644A28778/CCAPI/cc_api_display_ie_subfields:
cisco-ani=96XXXXXX
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=22XXXXXX
cisco-desttype=0
cisco-destplan=0
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
037302: *Sep 27 12:26:53.206: //-1/EBF644A28778/CCAPI/cc_api_call_setup_ind_common:
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=2238
037303: *Sep 27 12:26:53.206: //-1/EBF644A28778/CCAPI/ccCheckClipClir:
037304: *Sep 27 12:26:53.206: //-1/EBF644A28778/CCAPI/ccCheckClipClir:
037305: *Sep 27 12:26:53.206: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
037306: *Sep 27 12:26:53.206: :cc_get_feature_vsa malloc success
037307: *Sep 27 12:26:53.206: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
037308: *Sep 27 12:26:53.206: cc_get_feature_vsa count is 1
037309: *Sep 27 12:26:53.206: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
037310: *Sep 27 12:26:53.206: :FEATURE_VSA attributes are: feature_name:0,feature_time:140146424550188,feature_id:605
037311: *Sep 27 12:26:53.206: //2238/EBF644A28778/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
037312: *Sep 27 12:26:53.206: //2238/EBF644A28778/CCAPI/cc_process_call_setup_ind:
Event=0x7F7661DC4DD8
037313: *Sep 27 12:26:53.206: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
037314: *Sep 27 12:26:53.206: //2238/EBF644A28778/CCAPI/ccCallSetContext:
Context=0x7F7667D131E0
037315: *Sep 27 12:26:53.206: //2238/EBF644A28778/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 2238 with tag 100 to app "_ManagedAppProcess_Default"
037316: *Sep 27 12:26:53.207: //2238/EBF644A28778/CCAPI/ccCallProceeding:
037317: *Sep 27 12:26:53.207: //2238/EBF644A28778/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=300, Params=0x7F7667D20160, Progress Indication=NULL(0)
037318: *Sep 27 12:26:53.207: //2238/EBF644A28778/CCAPI/ccCheckClipClir:
037319: *Sep 27 12:26:53.207: //2238/EBF644A28778/CCAPI/ccCheckClipClir:
037320: *Sep 27 12:26:53.207: //2238/EBF644A28778/CCAPI/ccCallSetupRequest:
037321: *Sep 27 12:26:53.207: //2238/EBF644A28778/CCAPI/ccCallSetupRequest:
Guid=EBF644A2-E058-11E9-8778-D6D506AEE7C8, Outgoing Dial-peer=300
037322: *Sep 27 12:26:53.207: //2238/EBF644A28778/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-ani=96XXXXXX
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=101
cisco-desttype=0
cisco-destplan=0
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
037323: *Sep 27 12:26:53.208: //2238/EBF644A28778/CCAPI/ccIFCallSetupRequestPrivate:
037324: *Sep 27 12:26:53.208: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
037325: *Sep 27 12:26:53.208: :cc_get_feature_vsa malloc success
037326: *Sep 27 12:26:53.208: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
037327: *Sep 27 12:26:53.208: cc_get_feature_vsa count is 2
037328: *Sep 27 12:26:53.208: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
037329: *Sep 27 12:26:53.208: :FEATURE_VSA attributes are: feature_name:0,feature_time:140146424549740,feature_id:606
037330: *Sep 27 12:26:53.208: //2239/EBF644A28778/CCAPI/ccIFCallSetupRequestPrivate:
037331: *Sep 27 12:26:53.208: //2239/EBF644A28778/CCAPI/ccCallSetContext:
Context=0x7F7667D200E0
037332: *Sep 27 12:26:53.208: //2238/EBF644A28778/CCAPI/ccSaveDialpeerTag:
037333: *Sep 27 12:26:53.209: //2239/EBF644A28778/CCAPI/ccGetMediaClassTag:
media class tag 0
037334: *Sep 27 12:26:53.209: //2239/EBF644A28778/CCAPI/ccSetMediaclassIp2ipTags:
037335: *Sep 27 12:26:53.209: //2238/EBF644A28778/CCAPI/ccGetMediaClassTag:
media class tag 0
037336: *Sep 27 12:26:53.209: //2238/EBF644A28778/CCAPI/ccSetMediaclassIp2ipTags:
037337: *Sep 27 12:26:53.209: //2239/EBF644A28778/CCAPI/ccGet_xc_nr_asp_info:
037338: *Sep 27 12:26:53.209: //2238/EBF644A28778/CCAPI/ccGet_xc_nr_asp_info:
037339: *Sep 27 12:26:53.209: //2238/EBF644A28778/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Fri, 27 Sep 2019 12:26:53 GMT
Session-ID: 00000000000000000000000000000000;remote=ed7f5dd65c56522684fed1c27f2bd21f
Content-Length: 0
037340: *Sep 27 12:26:53.211: %VOICE_IEC-3-GW: H323: Internal Error (Socket error): IEC=1.1.186.5.7.6 on callID 2239 GUID=EBF644A2E05811E98778D6D506AEE7C8
037341: *Sep 27 12:26:53.211: //2239/EBF644A28778/CCAPI/cc_api_call_disconnected:
Cause Value=38, Interface=0x7F76560C7758, Call Id=2239
037342: *Sep 27 12:26:53.211: //2239/EBF644A28778/CCAPI/cc_api_call_disconnected:
Call Entry(Responsed=TRUE, Cause Value=38, Retry Count=0)
037343: *Sep 27 12:26:53.211: //2238/EBF644A28778/CCAPI/ccCallReleaseResources:
release reserved xcoding resource.
037344: *Sep 27 12:26:53.211: //2239/EBF644A28778/CCAPI/ccCallSetAAA_Accounting:
Accounting=0, Call Id=2239
037345: *Sep 27 12:26:53.211: //2239/EBF644A28778/CCAPI/ccCallDisconnect:
Cause Value=38, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=38)
037346: *Sep 27 12:26:53.211: //2239/EBF644A28778/CCAPI/ccCallDisconnect:
Cause Value=38, Call Entry(Responsed=TRUE, Cause Value=38)
037347: *Sep 27 12:26:53.211: //2239/EBF644A28778/CCAPI/cc_api_get_transfer_info:
037348: *Sep 27 12:26:53.211: //2239/EBF644A28778/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7F76560C7758, Tag=0x0, Call Id=2239,
Call Entry(Disconnect Cause=38, Voice Class Cause Code=0, Retry Count=0)
037349: *Sep 27 12:26:53.211: //2239/EBF644A28778/CCAPI/cc_api_call_disconnect_done:
037350: *Sep 27 12:26:53.212: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
037351: *Sep 27 12:26:53.212: :cc_free_feature_vsa freeing 7F7661DA1160
037352: *Sep 27 12:26:53.212: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
037353: *Sep 27 12:26:53.212: vsacount in free is 1
037354: *Sep 27 12:26:53.212: //2238/EBF644A28778/CCAPI/ccCallDisconnect:
Cause Value=38, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
037355: *Sep 27 12:26:53.212: //2238/EBF644A28778/CCAPI/ccCallDisconnect:
037356: *Sep 27 12:26:53.212: //2238/EBF644A28778/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 503 Service Unavailable
To: "22XXXXXX 22XXXXXX" <sip:22XXXXXX@trunk.cyta.com.cy>;cscf;tag=96D352C-18B4
Reason: Q.850;cause=38
Content-Length: 0
037357: *Sep 27 12:26:53.217: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:22XXXXXX@10.249.49.90:5060 SIP/2.0
Max-Forwards: 70
To: "22XXXXXX 22XXXXXX" <sip:22XXXXXX@trunk.cyta.com.cy>;tag=96D352C-18B4;cscf
CSeq: 956703344 ACK
Content-Length: 0
037358: *Sep 27 12:26:53.217: //2238/EBF644A28778/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7F76560DEB08, Tag=0x0, Call Id=2238,
037359: *Sep 27 12:26:53.217: //2238/EBF644A28778/CCAPI/cc_api_call_disconnect_done:
037360: *Sep 27 12:26:53.217: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
037361: *Sep 27 12:26:53.217: :cc_free_feature_vsa freeing 7F7661DA1320
037362: *Sep 27 12:26:53.217: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
037363: *Sep 27 12:26:53.217: vsacount in free is 0
037364: *Sep 27 12:26:58.605: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CANCEL sip:22XXXXXX@10.249.49.90:5060 SIP/2.0
Max-Forwards: 17
CSeq: 956703344 CANCEL
Content-Length: 0
037365: *Sep 27 12:26:58.606: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 481 Call Leg/Transaction Does Not Exist
Content-Length: 0
There is no INVITE sent towards CUCM, you are just receiving INVITEs from your service provider.
This means there must be something wrong with your dial-peer pointing to CUCM.
Please add the following commands to your dial-peer 300:
session transport udp or tcp (depence what you defined in the sip trunk security profile)
Peter
I have change that and there is an invite to the CUCM.
Still issue to call in.
One thing that i see is that codec is sending is the g729 but my provider doent suppport it
How do i change the codec to g711alaw to mach the providers codec
I normally specify the codecs in the following way:
create a voice codec class in global configuration mode:
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
codec preference 4 g729br8
Then apply this class to the dial-peers where you need it:
voice-class codec 1
Check also, that your Region/Codec Preference List in CUCM is fine.
Hope this helps
Peter
Hello ,
I have the codec changes but still no rining the extension. Here is the debug log
001377: *Sep 30 13:14:04.923: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 17
Via: SIP/2.0/UDP 10.224.150.7:5060;branch=z9hG4bKg3Zqkv7iw3hixyqc4szy89z91w5e67y6m
From: <sip:22XXXXXX@fmc.cyta.com.cy;user=phone>;tag=h7g4Esbg_918501649-1569838511741-
Call-ID: BW1315117413009191460153843@10.224.112.10
CSeq: 13982527 INVITE
Min-Se: 600
P-Asserted-Identity: <sip:22XXXXXX@fmc.cyta.com.cy;user=phone>
Privacy: none
Content-Length: 296
v=0
o=BroadWorks 90661930 1 IN IP4 10.224.150.7
s=-
t=0 0
m=audio 29788 RTP/AVP 8 18 100
a=fmtp:18 annexb=no
a=fmtp:100 0-15
a=sqn: 0
a=sendrecv
a=ptime:20
001378: *Sep 30 13:14:04.925: //-1/0309B1B9806F/CCAPI/cc_api_display_ie_subfields:
cisco-username=22XXXXXX
cisco-ani=22XXXXXX
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=22XXXXXX
cisco-desttype=0
cisco-destplan=0
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
001379: *Sep 30 13:14:04.925: //-1/0309B1B9806F/CCAPI/cc_api_call_setup_ind_common:
Interface=0x7F625EE5BB08, Call Info(
Calling Number=22XXXXXX,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=158
001380: *Sep 30 13:14:04.925: //-1/0309B1B9806F/CCAPI/ccCheckClipClir:
In: Calling Number=22XXXXXX(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
001381: *Sep 30 13:14:04.925: //-1/0309B1B9806F/CCAPI/ccCheckClipClir:
Out: Calling Number=22XXXXXX(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
001382: *Sep 30 13:14:04.925: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
001383: *Sep 30 13:14:04.925: :cc_get_feature_vsa malloc success
001384: *Sep 30 13:14:04.925: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
001385: *Sep 30 13:14:04.925: cc_get_feature_vsa count is 1
001386: *Sep 30 13:14:04.925: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
001387: *Sep 30 13:14:04.925: :FEATURE_VSA attributes are: feature_name:0,feature_time:140060683598156,feature_id:35
001388: *Sep 30 13:14:04.925: //158/0309B1B9806F/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=22XXXXXX(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
001389: *Sep 30 13:14:04.926: //158/0309B1B9806F/CCAPI/cc_process_call_setup_ind:
Event=0x7F626B4D2C08
001390: *Sep 30 13:14:04.926: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
001391: *Sep 30 13:14:04.926: //158/0309B1B9806F/CCAPI/ccCallSetContext:
Context=0x7F6271410BE0
001392: *Sep 30 13:14:04.926: //158/0309B1B9806F/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 158 with tag 100 to app "_ManagedAppProcess_Default"
001393: *Sep 30 13:14:04.926: //158/0309B1B9806F/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Mon, 30 Sep 2019 13:14:04 GMT
Session-ID: 00000000000000000000000000000000;remote=8b88fc3c8d3855b790b27348a3227b35
Content-Length: 0
001394: *Sep 30 13:14:04.927: //158/0309B1B9806F/CCAPI/ccCallProceeding:
001395: *Sep 30 13:14:04.927: //158/0309B1B9806F/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=300, Params=0x7F6271412360, Progress Indication=NULL(0)
001396: *Sep 30 13:14:04.927: //158/0309B1B9806F/CCAPI/ccCheckClipClir:
001397: *Sep 30 13:14:04.927: //158/0309B1B9806F/CCAPI/ccCheckClipClir:
001398: *Sep 30 13:14:04.927: //158/0309B1B9806F/CCAPI/ccCallSetupRequest:
001399: *Sep 30 13:14:04.927: //158/0309B1B9806F/CCAPI/ccCallSetupRequest:
Account Number=22XXXXXX, Final Destination Flag=TRUE,
Guid=0309B1B9-E2BB-11E9-806F-C99057E543F2, Outgoing Dial-peer=300
001400: *Sep 30 13:14:04.927: //158/0309B1B9806F/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-ani=22XXXXXX
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=101
cisco-desttype=0
cisco-destplan=0
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
001401: *Sep 30 13:14:04.928: //158/0309B1B9806F/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x7F625EE5BB08, Interface Type=3, Destination=, Mode=0x0,
Call Params(Calling Number=22XXXXXX,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
001402: *Sep 30 13:14:04.928: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
001403: *Sep 30 13:14:04.928: :cc_get_feature_vsa malloc success
001404: *Sep 30 13:14:04.928: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
001405: *Sep 30 13:14:04.928: cc_get_feature_vsa count is 2
001406: *Sep 30 13:14:04.928: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
001407: *Sep 30 13:14:04.928: :FEATURE_VSA attributes are: feature_name:0,feature_time:140060683597932,feature_id:36
001408: *Sep 30 13:14:04.928: //158/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
001409: *Sep 30 13:14:04.928: cc_api_get_xcode_stream : 4981
001410: *Sep 30 13:14:04.928: //158/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
001411: *Sep 30 13:14:04.928: cc_api_get_xcode_stream : 4981
001412: *Sep 30 13:14:04.928: //158/0309B1B9806F/CCAPI/cc_api_event_indication:
Event=101, Call Id=158
001413: *Sep 30 13:14:04.928: //158/0309B1B9806F/CCAPI/cc_api_event_indication:
Event Is Sent To Conferenced SPI(s) Directly
001414: *Sep 30 13:14:04.928: //159/0309B1B9806F/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
001415: *Sep 30 13:14:04.928: //159/0309B1B9806F/CCAPI/ccCallSetContext:
Context=0x7F62714122E0
001416: *Sep 30 13:14:04.928: //158/0309B1B9806F/CCAPI/ccSaveDialpeerTag:
001417: *Sep 30 13:14:04.929: //159/0309B1B9806F/CCAPI/ccGetMediaClassTag:
media class tag 0
001418: *Sep 30 13:14:04.929: //159/0309B1B9806F/CCAPI/ccSetMediaclassIp2ipTags:
001419: *Sep 30 13:14:04.929: //158/0309B1B9806F/CCAPI/ccGetMediaClassTag:
media class tag 0
001420: *Sep 30 13:14:04.929: //158/0309B1B9806F/CCAPI/ccSetMediaclassIp2ipTags:
001421: *Sep 30 13:14:04.929: //159/0309B1B9806F/CCAPI/ccGet_xc_nr_asp_info:
001422: *Sep 30 13:14:04.929: //158/0309B1B9806F/CCAPI/ccGet_xc_nr_asp_info:
001423: *Sep 30 13:14:04.929: //-1/xxxxxxxxxxxx/CCAPI/cc_is_cng_fax_detect_active:
Call Id 158
001424: *Sep 30 13:14:04.929: //159/0309B1B9806F/CCAPI/ccGetMediaClassTag:
media class tag 0
001425: *Sep 30 13:14:04.929: //159/0309B1B9806F/CCAPI/ccSetMediaclassIp2ipTags:
001426: *Sep 30 13:14:04.929: //158/0309B1B9806F/CCAPI/ccGetMediaClassTag:
media class tag 0
001427: *Sep 30 13:14:04.929: //158/0309B1B9806F/CCAPI/ccSetMediaclassIp2ipTags:
001428: *Sep 30 13:14:04.929: //159/0309B1B9806F/CCAPI/ccGet_xc_nr_asp_info:
001429: *Sep 30 13:14:04.929: //158/0309B1B9806F/CCAPI/ccGet_xc_nr_asp_info:
001430: *Sep 30 13:14:04.929: //-1/xxxxxxxxxxxx/CCAPI/cc_is_cng_fax_detect_active:
Call Id 159
001431: *Sep 30 13:14:04.929: //-1/xxxxxxxxxxxx/CCAPI/cc_is_cng_fax_detect_active:
Call Id 158
001432: *Sep 30 13:14:04.929: //159/0309B1B9806F/CCAPI/cc_api_call_disconnected:
Cause Value=47, Interface=0x7F625EE5BB08, Call Id=159
001433: *Sep 30 13:14:04.930: //159/0309B1B9806F/CCAPI/cc_api_call_disconnected:
Call Entry(Responsed=TRUE, Cause Value=47, Retry Count=0)
001434: *Sep 30 13:14:04.930: //158/0309B1B9806F/CCAPI/ccCallReleaseResources:
001435: *Sep 30 13:14:04.930: //159/0309B1B9806F/CCAPI/ccCallSetAAA_Accounting:
Accounting=0, Call Id=159
001436: *Sep 30 13:14:04.930: //159/0309B1B9806F/CCAPI/ccCallDisconnect:
001437: *Sep 30 13:14:04.930: //159/0309B1B9806F/CCAPI/ccCallDisconnect:
001438: *Sep 30 13:14:04.930: //159/0309B1B9806F/CCAPI/cc_api_call_disconnect_done:
Disposition=-11, Interface=0x7F625EE5BB08, Tag=0x0, Call Id=159,
001439: *Sep 30 13:14:04.930: //159/0309B1B9806F/CCAPI/cc_api_call_disconnect_done:
001440: *Sep 30 13:14:04.930: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
001441: *Sep 30 13:14:04.930: :cc_free_feature_vsa freeing 7F626B4AF860
001442: *Sep 30 13:14:04.930: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
001443: *Sep 30 13:14:04.930: vsacount in free is 1
001444: *Sep 30 13:14:04.931: //158/0309B1B9806F/CCAPI/ccCallDisconnect:
001445: *Sep 30 13:14:04.931: //158/0309B1B9806F/CCAPI/ccCallDisconnect:
001446: *Sep 30 13:14:04.931: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 17
Via: SIP/2.0/UDP 10.224.150.7:5060;branch=z9hG4bKg3Zqkv7iyp4e2x5tnkbqkiv41olxe7zqs
Min-Se: 600
Privacy: none
Content-Length: 297
v=0
s=-
t=0 0
m=audio 57292 RTP/AVP 8 18 100
a=fmtp:18 annexb=no
a=fmtp:100 0-15
a=sqn: 0
a=sendrecv
a=ptime:20
001447: *Sep 30 13:14:04.931: //158/0309B1B9806F/CCAPI/cc_api_call_disconnected:
Cause Value=47, Interface=0x7F625EE5BB08, Call Id=158
001448: *Sep 30 13:14:04.931: //158/0309B1B9806F/CCAPI/cc_api_call_disconnected:
001449: *Sep 30 13:14:04.931: //158/0309B1B9806F/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7F625EE5BB08, Tag=0x0, Call Id=158,
001450: *Sep 30 13:14:04.932: //158/0309B1B9806F/CCAPI/cc_api_call_disconnect_done:
001451: *Sep 30 13:14:04.932: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
001452: *Sep 30 13:14:04.932: :cc_free_feature_vsa freeing 7F626B4AF940
001453: *Sep 30 13:14:04.932: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
001454: *Sep 30 13:14:04.932: vsacount in free is 0
001455: *Sep 30 13:14:05.430: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 17
Min-Se: 600
Privacy: none
Content-Length: 297
v=0
s=-
t=0 0
a=fmtp:18 annexb=no
a=fmtp:100 0-15
a=sqn: 0
a=sendrecv
a=ptime:20
001456: *Sep 30 13:14:05.432: //-1/03570F8E8075/CCAPI/cc_api_display_ie_subfields:
cisco-ani=22XXXXXX
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=22XXXXXX
cisco-desttype=0
cisco-destplan=0
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
001457: *Sep 30 13:14:05.432: //-1/03570F8E8075/CCAPI/cc_api_call_setup_ind_common:
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=160
001458: *Sep 30 13:14:05.432: //-1/03570F8E8075/CCAPI/ccCheckClipClir:
001459: *Sep 30 13:14:05.432: //-1/03570F8E8075/CCAPI/ccCheckClipClir:
001460: *Sep 30 13:14:05.432: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
001461: *Sep 30 13:14:05.432: :cc_get_feature_vsa malloc success
001462: *Sep 30 13:14:05.433: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
001463: *Sep 30 13:14:05.433: cc_get_feature_vsa count is 1
001464: *Sep 30 13:14:05.433: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
001465: *Sep 30 13:14:05.433: :FEATURE_VSA attributes are: feature_name:0,feature_time:140060683598156,feature_id:37
001466: *Sep 30 13:14:05.433: //160/03570F8E8075/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
001467: *Sep 30 13:14:05.433: //160/03570F8E8075/CCAPI/cc_process_call_setup_ind:
Event=0x7F626B4D1538
001468: *Sep 30 13:14:05.433: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
001469: *Sep 30 13:14:05.433: //160/03570F8E8075/CCAPI/ccCallSetContext:
Context=0x7F62714150E0
001470: *Sep 30 13:14:05.433: //160/03570F8E8075/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 160 with tag 100 to app "_ManagedAppProcess_Default"
001471: *Sep 30 13:14:05.433: //160/03570F8E8075/CCAPI/ccCallProceeding:
001472: *Sep 30 13:14:05.434: //160/03570F8E8075/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=300, Params=0x7F6271413A60, Progress Indication=NULL(0)
001473: *Sep 30 13:14:05.434: //160/03570F8E8075/CCAPI/ccCheckClipClir:
001474: *Sep 30 13:14:05.434: //160/03570F8E8075/CCAPI/ccCheckClipClir:
001475: *Sep 30 13:14:05.434: //160/03570F8E8075/CCAPI/ccCallSetupRequest:
001476: *Sep 30 13:14:05.434: //160/03570F8E8075/CCAPI/ccCallSetupRequest:
Guid=03570F8E-E2BB-11E9-8075-C99057E543F2, Outgoing Dial-peer=300
001477: *Sep 30 13:14:05.434: //160/03570F8E8075/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-ani=22XXXXXX
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=101
cisco-desttype=0
cisco-destplan=0
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
001478: *Sep 30 13:14:05.434: //160/03570F8E8075/CCAPI/ccIFCallSetupRequestPrivate:
001479: *Sep 30 13:14:05.435: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
001480: *Sep 30 13:14:05.435: :cc_get_feature_vsa malloc success
001481: *Sep 30 13:14:05.435: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
001482: *Sep 30 13:14:05.435: cc_get_feature_vsa count is 2
001483: *Sep 30 13:14:05.435: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
001484: *Sep 30 13:14:05.435: :FEATURE_VSA attributes are: feature_name:0,feature_time:140060683597932,feature_id:38
001485: *Sep 30 13:14:05.435: //160/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
001486: *Sep 30 13:14:05.435: cc_api_get_xcode_stream : 4981
001487: *Sep 30 13:14:05.435: //160/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
001488: *Sep 30 13:14:05.435: cc_api_get_xcode_stream : 4981
001489: *Sep 30 13:14:05.435: //160/03570F8E8075/CCAPI/cc_api_event_indication:
Event=101, Call Id=160
001490: *Sep 30 13:14:05.435: //160/03570F8E8075/CCAPI/cc_api_event_indication:
001491: *Sep 30 13:14:05.435: //161/03570F8E8075/CCAPI/ccIFCallSetupRequestPrivate:
001492: *Sep 30 13:14:05.435: //161/03570F8E8075/CCAPI/ccCallSetContext:
Context=0x7F62714139E0
001493: *Sep 30 13:14:05.435: //160/03570F8E8075/CCAPI/ccSaveDialpeerTag:
001494: *Sep 30 13:14:05.435: //161/03570F8E8075/CCAPI/ccGetMediaClassTag:
media class tag 0
001495: *Sep 30 13:14:05.435: //161/03570F8E8075/CCAPI/ccSetMediaclassIp2ipTags:
001496: *Sep 30 13:14:05.435: //160/03570F8E8075/CCAPI/ccGetMediaClassTag:
media class tag 0
001497: *Sep 30 13:14:05.436: //160/03570F8E8075/CCAPI/ccSetMediaclassIp2ipTags:
001498: *Sep 30 13:14:05.436: //161/03570F8E8075/CCAPI/ccGet_xc_nr_asp_info:
001499: *Sep 30 13:14:05.436: //160/03570F8E8075/CCAPI/ccGet_xc_nr_asp_info:
001500: *Sep 30 13:14:05.436: //-1/xxxxxxxxxxxx/CCAPI/cc_is_cng_fax_detect_active:
Call Id 160
001501: *Sep 30 13:14:05.436: //161/03570F8E8075/CCAPI/ccGetMediaClassTag:
media class tag 0
001502: *Sep 30 13:14:05.436: //161/03570F8E8075/CCAPI/ccSetMediaclassIp2ipTags:
001503: *Sep 30 13:14:05.436: //160/03570F8E8075/CCAPI/ccGetMediaClassTag:
media class tag 0
001504: *Sep 30 13:14:05.436: //160/03570F8E8075/CCAPI/ccSetMediaclassIp2ipTags:
001505: *Sep 30 13:14:05.436: //161/03570F8E8075/CCAPI/ccGet_xc_nr_asp_info:
001506: *Sep 30 13:14:05.436: //160/03570F8E8075/CCAPI/ccGet_xc_nr_asp_info:
001507: *Sep 30 13:14:05.436: //-1/xxxxxxxxxxxx/CCAPI/cc_is_cng_fax_detect_active:
Call Id 161
001508: *Sep 30 13:14:05.436: //-1/xxxxxxxxxxxx/CCAPI/cc_is_cng_fax_detect_active:
Call Id 160
001509: *Sep 30 13:14:05.436: //161/03570F8E8075/CCAPI/cc_api_call_disconnected:
Cause Value=47, Interface=0x7F625EE5BB08, Call Id=161
001510: *Sep 30 13:14:05.436: //161/03570F8E8075/CCAPI/cc_api_call_disconnected:
001511: *Sep 30 13:14:05.436: //160/03570F8E8075/CCAPI/ccCallReleaseResources:
001512: *Sep 30 13:14:05.436: //161/03570F8E8075/CCAPI/ccCallSetAAA_Accounting:
Accounting=0, Call Id=161
001513: *Sep 30 13:14:05.436: //161/03570F8E8075/CCAPI/ccCallDisconnect:
001514: *Sep 30 13:14:05.437: //161/03570F8E8075/CCAPI/ccCallDisconnect:
001515: *Sep 30 13:14:05.437: //161/03570F8E8075/CCAPI/cc_api_call_disconnect_done:
Disposition=-11, Interface=0x7F625EE5BB08, Tag=0x0, Call Id=161,
001516: *Sep 30 13:14:05.437: //161/03570F8E8075/CCAPI/cc_api_call_disconnect_done:
001517: *Sep 30 13:14:05.437: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
001518: *Sep 30 13:14:05.437: :cc_free_feature_vsa freeing 7F626B4AF860
001519: *Sep 30 13:14:05.437: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
001520: *Sep 30 13:14:05.437: vsacount in free is 1
001521: *Sep 30 13:14:05.437: //160/03570F8E8075/CCAPI/ccCallDisconnect:
001522: *Sep 30 13:14:05.437: //160/03570F8E8075/CCAPI/ccCallDisconnect:
001523: *Sep 30 13:14:05.437: //160/03570F8E8075/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Mon, 30 Sep 2019 13:14:05 GMT
Session-ID: 00000000000000000000000000000000;remote=3764f992a1bf57c5a470e62e8d6603c3
Content-Length: 0
001524: *Sep 30 13:14:05.438: //160/03570F8E8075/SIP/Msg/ccsipDisplayMsg:
Sent:
To: "22XXXXXX 22XXXXXX" <sip:22XXXXXX@trunk.cyta.com.cy>;cscf;tag=FFD8DC-2048
Warning: 399 10.249.49.90 "Transcoder Not Configured"
Reason: Q.850;cause=47
Content-Length: 0
001525: *Sep 30 13:14:05.443: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
To: "22XXXXXX 22XXXXXX" <sip:22XXXXXX@trunk.cyta.com.cy>;tag=FFD8DC-2048;cscf
CSeq: 13982527 ACK
Content-Length: 0
001526: *Sep 30 13:14:05.443: //160/03570F8E8075/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7F625EE5BB08, Tag=0x0, Call Id=160,
001527: *Sep 30 13:14:05.443: //160/03570F8E8075/CCAPI/cc_api_call_disconnect_done:
001528: *Sep 30 13:14:05.443: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
001529: *Sep 30 13:14:05.443: :cc_free_feature_vsa freeing 7F626B4AF940
001530: *Sep 30 13:14:05.443: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
001531: *Sep 30 13:14:05.443: vsacount in free is 0
001532: *Sep 30 13:14:10.839: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 17
CSeq: 13982527 CANCEL
Content-Length: 0
001533: *Sep 30 13:14:10.839: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Content-Length: 0
Sorry, but in your debug output I still don't see an INVITE going out of your CUBE towards CUCM. There are just incoming INVITEs from your service provider. For me this looks like something is wrong with your SIP connection to CUCM.
Can you please post your CUBE configuration and please all that is relevant to voice.
Peter
Here it is
voice service voip
ip address trusted list
ipv4 87.228.193.84
ipv4 10.224.116.80
ipv4 192.168.1.102
ipv4 10.224.50.7
ipv4 10.224.0.0 255.255.0.0
mode border-element license capacity 10
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
outbound-proxy ipv4:10.224.150.7:5060
no call service stop
voice class codec 1
voice iec syslog
rule 1 /22203560/ /101/
interface GigabitEthernet0/0/0
description WAN
ip address 10.10.10.54 255.255.255.0
umbrella out
negotiation auto
interface GigabitEthernet0/0/1
description LAN-TEL-Server
ip address 192.168.1.254 255.255.255.0
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
telephony-service
max-conferences 8 gain -6
transfer-system full-consult
session target ipv4:10.224.150.7
incoming called-number 22203560
voice-class codec 1
dtmf-relay rtp-nte
no vad
session target ipv4:192.168.1.102
dtmf-relay rtp-nte
codec g711alaw
no vad
Ok, let's start at the top of your configuration.
- In the INVITE of your service provider is an IP address 10.249.49.90, but this address is not in your "ip address trusted list".
- on dial-peer 100 replace the incoming called-number with a wild card like a dot or 0. .
- on dial-peer 300 add the voice-class codec 1 as well
Finally you should see an INVITE that looks similar to the following (snip):
Sent:
INVITE sip:101@192.168.1.102 SIP/2.0 Max-Forwards: 17 Via: SIP/2.0/UDP 10.10.10.54:5060;branch=z9hG4bKxxxxxxxxxxxxx To: "101" <sip:101@trunk.cyta.com.cy>;cscf From: <sip:22XXXXXX@fmc.cyta.com.cy;user=phone>;tag=xxxxxxx
As you can see this INVITE is addressed to the IP address of your CUCM.
Cisco has an online tool, where you can check your dialplan of the CUBE: https://cway.cisco.com/tools/DNACube
Hope this helps
Peter
Please verify your region settings between phone and CUCM, CUCM to CUBE. In your debugs there is cause code of 47 which means no resources. Looks like some media resource is needed in order to complete the call.
Also, add the bind interface command in your dial-peers.
HTH.
The INVITE message that you are receiving from Service Provider doesn't include valid called and calling number:
Max-Forwards: 17
From: <sip:22XXXXXX@fmc.cyta.com.cy;user=phone>;tag=h7g4Esbg_918501649-1569838511741- Call-ID: BW1315117413009191460153843@10.224.112.10 CSeq: 13982527 INVITE Contact: <sip:sgc_c@10.224.150.7;transport=udp> Record-Route: <sip:10.224.150.7;transport=udp;lr> Min-Se: 600 P-Asserted-Identity: <sip:22XXXXXX@fmc.cyta.com.cy;user=phone>
Please check with your service provider whether they are sending correct calling and called number.
Also, I would recommend following add-on changes to your CUBE configuration:
voice service voip
 no supplementary-service sip moved-temporarily
 no supplementary-service sip refer
 supplementary-service media-renegotiate
 sip
  no outbound-proxy ipv4:10.224.150.7:5060
  header-passing
  error-passthru
  options-ping 60
  no update-callerid
  early-offer forced
  midcall-signaling passthru
  privacy-policy passthru
no dial-peer voice 100 voip
no dial-peer voice 300 voip
dial-peer voice 1000 voip
 description ** INBOUND CALLS FROM CUCM CLUSTER **
 incoming called-number [2-9].......$
 voice-class codec 1
 voice-class sip early-offer forced
 voice-class sip bind control source-interface GigabitEthernet0/0/1
 voice-class sip bind media source-interface GigabitEthernet0/0/1
 dtmf-relay rtp-nte
 no vad
dial-peer voice 1001 voip
 description ** OUTBOUND CALLS TO CUCM CLUSTER **
 destination-pattern 1..$
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
dial-peer voice 9000 voip
 description ** INBOUND CALLS FROM SERVICE PROVIDER **
 incoming called-number 22203560$
 voice-class codec 1
 voice-class sip bind control source-interface GigabitEthernet0/0/0
 voice-class sip bind media source-interface GigabitEthernet0/0/0
 dtmf-relay rtp-nte
 no vad
dial-peer voice 9001 voip
 description ** OUTGOING CALLS TO SERVICE PROVIDER **
 destination-pattern [2-9].......$
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
