Incoming calls not working in SRST mode
martin.franklyn
I am getting a problem with incoming calls in SRST mode.The only way I get incoming calls to work in SRST mode is that I have to shutdown all the following dial-peers which was automatically created.
dial-peer voice 999000 pots
 service mgcpapp
 port 0/0/0
 shutdown
dial-peer voice 999001 pots
 service mgcpapp
 port 0/0/1
 shutdown
voice-port 0/0/0
 supervisory disconnect dualtone mid-call
 timeouts call-disconnect 5
 timeouts wait-release 5
 timing hookflash-out 50
 timing guard-out 1000
 connection plar opx 21
 caller-id enable
voice-port 0/0/1
 caller-id enable
dial-peer voice 868 pots
 service mgcpapp
 incoming called-number .
 direct-inward-dial
 port 0/0/0
dial-peer voice 869 pots
 service mgcpapp
 direct-inward-dial
 port 0/0/1
I did this because when I did a debug I realized that the incoming call was using one of the above dial-peer and not using the dial-peer that was created for incoming calls. The problem is when I shutdown these dial-peers the ports do not work in normal mode.
Any ideas?
Thanks in advance,
Martin
Brandon Buffin
Couple of things:
1. Do you have MGCP fallback configured, such as:
R(config)#application
R(config-app)#global
R(config-app-global)#service alternate Default
2. You will need destination patterns on your POTS dial peers for when MGCP fallback is active:
 service mgcpapp
 destination-pattern 9T
 port 0/0/0
Brandon
Dennis Mink
Martin,
rip the service mgcpapp command off your dial peers, and only configure the mgcp global commands:
mgcp
mgcp call-agent 1.1.1.1 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp profile default
the dial-peer 869 should then take over as the incoming dial-peer.
the thing you will have to remember is that in a fail over scenario, you will need an independent dial plan on your VGW. a minumum of an inbound dial-peer and an outbound for PSTN calls, like the 9T pattern that Brandon suggested.
Please remember to rate useful posts, by clicking on the stars below.
Hi Guys,
I will try these suggestions when I go back to the customer's site. Thanks for replying.
Martin.
