Hello Roy
You can run the debugs on the gateway depending upon the protocol being used. Do a show log and you would get to know if the call has actually come in or not. By this you should be able to track down your call.
Abhay Reyal
Abhay Singh Reyal
The Only Way To Do Great Work Is To Love What You Do. If You Haven’t Found It Yet, Keep Looking. Don’t Settle
