09-14-2015 04:24 AM - edited 03-17-2019 04:17 AM
hi, i have some problem on my CME router.
i have 4 pstn line, with phone number ******12, ******13, ******15, ******16.
when someone call to number ******12 the ip phone showing "Unknown Number" on the display, but when someone call another number the caller id will showing on the display.
voice-port 0/1/0
cptone ID
connection plar opx 76310
caller-id enable
voice-port 0/1/1
cptone ID
caller-id enable
voice-port 0/1/2
cptone ID
caller-id enable
voice-port 0/1/3
cptone ID
caller-id enable
i'va made sure the caller id active on TELCO side.
when i test calling ******12, i got a delay (ringging delay) around 1-3 seconds between my phone to the ip phone.
but, when i test calling another number, i got no delay.
the attachment belows is "debug vpm signal"
Solved! Go to Solution.
09-14-2015 04:47 AM
For the non working call we see the following
Sep 13 16:27:02.443: [0/1/0] get_fxo_caller_id:Caller ID receive failed. parseCallerIDString:no data. Sep 13 16:27:02.443: [0/1/0] get_local_station_id calling num= calling name= calling time=09/13 16:27 orig called= Sep 13 16:27:02.447: [0/1/0] htsp_dsm_close_done
Have you confirmed with Telco that they are sending the caller id correctly?
Manish
- Do rate helpful posts -
09-14-2015 04:47 AM
Manish
09-14-2015 04:51 AM
i have confirmed. Because when i used analog phone, the caller id show on the display.
10-07-2015 09:26 PM
the problem has been solved. its because the telco using cptone BR.
10-07-2015 09:28 PM
Thanks for updating the post with the resolution.
Manish
04-06-2016 07:37 AM
I had same issue.
We modified the supervisory tones to fix this issue, there was prefix "D" and post fix "C" in the caller ID as well that was addressed by this config.
voice class custom-cptone CUSSUPTONE
dualtone disconnect
frequency 450
cadence 350 350
voice-port 0/3/0
supervisory disconnect dualtone mid-call
supervisory custom-cptone CUSSUPTONE
no battery-reversal
connection plar 4321
description Line1
cptone CA
caller-id enable
caller-id mode DTMF start D end C
caller-id alerting line-reversal
caller-id alerting dsp-pre-allocate
09-14-2015 06:36 AM
It could be because you are missing connection plar opx 76310 on the voice-port 0/1/2
Try that please.
Secondly, could you please post output from voice ccapi inout as well
