Incomming Call Problem
Jawad Ahmad
Dears,
In our network we are facing problem, can not receive any incomming international call what I do.
can any tell me about translation rule for incomming dial peer like 13 digit to 4 digit
Only configuration won't help us till we don't know whether call is hitting router or not. Please also share the output of 'debug voice ccapi inout' and 'debug ccsip messages'.
- Vivek
7 Replies 7
Nadeem Ahmed
Jawad,
what is the call-flow topology? please share show run and debugs if you have collected any?
Br,
Nadeem Ahmed
PS: Please rate all useful post.
Br, Nadeem Please rate all useful post.
asalamoalaikom
Brother,
here's a configuration,
tanslation rules dial peers.
voice translation-rule 1
rule 1 /^7\(...\)/ /2997\1/
rule 2 /^58\(..\)/ /40858\1/
voice translation-rule 2
rule 1 /^011\(......\)/ /\1/
voice translation-profile outgoing
translate calling 1
translate called 2
dial-peer voice 5000 voip
destination-pattern 5000
session protocol sipv2
session target ipv4:192.168.125.2
dtmf-relay sip-notify rtp-nte
codec g711ulaw
no vad
dial-peer voice 10 voip
incoming called-number .
dtmf-relay rtp-nte
codec g711alaw
dial-peer voice 11 voip
destination-pattern 73..
session target ipv4:192.168.125.1
dial-peer voice 102 voip
corlist outgoing Mobile-Calls
translation-profile outgoing outgoing
destination-pattern 05........
session target ipv4:10.200.7.157
dtmf-relay rtp-nte
codec g711alaw
dial-peer voice 101 voip
corlist outgoing Local-Calls
destination-pattern 011.......
dtmf-relay rtp-nte
codec g711alaw
dial-peer voice 103 voip
destination-pattern 9[90].
dtmf-relay rtp-nte
codec g711alaw
dial-peer voice 104 voip
corlist outgoing Nationl-Calls
destination-pattern 9200.....
dtmf-relay rtp-nte
codec g711alaw
dial-peer voice 105 voip
destination-pattern 01[234,6-7].......
dtmf-relay rtp-nte
codec g711alaw
dial-peer voice 106 voip
destination-pattern 800.......
dtmf-relay rtp-nte
codec g711alaw
dial-peer voice 107 voip
destination-pattern 00T
dtmf-relay rtp-nte
codec g711alaw
dial-peer voice 108 voip
destination-pattern 83..
session target ipv4:192.168.141.1
dtmf-relay rtp-nte
codec g711alaw
dial-peer voice 109 voip
destination-pattern 58[5-9].
dtmf-relay rtp-nte
codec g711alaw
dial-peer voice 110 voip
destination-pattern 86..
session target ipv4:192.168.151.1
dtmf-relay rtp-nte
codec g711alaw
- Vivek
Vivek Batra
Please provide more information about your setup.
Your connection to Telco is PRI or SIP trunk?
If it is PRI, check with debug isdn q931 and see if that call is hitting your router or not. In case of SIP, check the same with debug ccsip messages and share the result.
Once I am having more information about your setup and call flow, can help you with translation rule as well.
- Vivek
we are using sip trunk.
Check using 'debug ccsip messages' and see call is hitting router or not. If it is hitting the router, share the logs else you need to check with your service provider.
- Vivek
ok thank you,
Once I get a logs will share here.
