incorrect Billing on transferred call on cdr
cnorton
                   Hi guys, good day! Just wondering if you have experience issues on billing for transferred calls? We just noticed that when a call is transferred, CDR recognize the call has ended even though the call leg is still active on our gateway's b channel. We are using cisco call manager 7 and 3825 cisco gateway router. Thanks in advance
Gordon Ross
Level 9
Level 9
You need to be a bit more specific about everything here. Where's the call being transfered to ? (on switch, off switch ?) What's billing incorrectly ? (Your telco, your call logger) ?
GTG
Please rate all helpful posts.
Hi Gordon,
Sorry about that. The calls are being transferred to any external number. And its our cdr that billing incorrectly. Thanks
Are you interpreting the CDRs correctly ? In this case, you will have multiple call legs, and hence have multiple CDR records for the one call.
GTG
Hi Gordon,
Please check screenshot of a sample cdr report. There is a record for when the outside number (a) calls our internal number (b) and when b dials an external number (c) but there is no record when a and c are connected after call wlas transferred by b. i did see that the call is still active on our trunk right after transferring so that should also be recorded on cdr.
