Increase the VM time
Rachna Sharma
Hi Guys,
Is there any way to increase the VM recording time upto 2 minutes.
Currently, the CME is not taking message more than 60 sec.
Rachna
Gajanan Pande
As you are using CME, I presume the VM system is CUE. Following commands should help you. Default recording time is 900 seconds or 15 mins.
voicemail recording time seconds
no voicemail recording time
Refer http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel3_2/Command/v_cmds.html#wp1017265
Pls rate helpful posts.
GP.
Gajanan Pande
GP.
Hi Gajanan,
Thanks. It helped and also resolves the issue with the disengage tone after the VM message.
Glad, I could assist.
GP.
