04-04-2011 01:19 AM - edited 03-16-2019 04:18 AM
I have a recurring issue where individual handsets within the same device pool are registering with a local SRST gateway. All of the handsets are plugged into the same switch there is no errors or physical issues on the handsets that seem to be registering with the local gateway.
Has anyone experienced this issue in the past? Also is there a way to manually unregister individual handsets.
04-04-2011 01:22 AM
Check the connectivity between the Switch and CUCM.
How many CUCM Servers are there in the CUCM Group?
/divin
04-04-2011 01:54 AM
It appears that ping is not allowed via the firewalls between the switch and the CM but connectivity between the sites is fine and this is only affecting 2 of 20 handsets that are all plugged into the same switch. There are two CUCM servers in total.
04-04-2011 03:39 AM
This issue was resolved by resolving a faulty patch lead, the errors were not displaying on the switch strangely enough.
Could anyone advise if there is a way to force a handset try and re-register with the CM?
