05-01-2007 04:15 AM - edited 03-14-2019 09:14 PM
Is it possible to insert a pause in a dial string using CCM 4.2? For example, on a voicemail speed dial a pause could be inserted after the VM extension and then a password could be automatically entered.
Thank you for the help
05-01-2007 04:20 AM
Hi Brian,
The "," (to add a 1 second pause)still only works on CME (BUMMER)
Telephone number to dialed. Represents a fully qualified E.164 number. Use a comma (,) to represent a one-second pause.
From this CME doc;
**For CCM it looks like Feature request/Bug CSCec41905 (ability to add pause in Speed dials) is still open :(
Hope this helps!
Rob
05-01-2007 04:23 AM
Thanks for the response Rob, looks like I'll have to wait for that feature.
05-01-2007 10:26 AM
The stuff I've read indicates that it is supported with H.323 Gateways, but not MGCP. However I've yet to see a specific example.
12-14-2007 11:01 AM
has Cisco ever resolved this issue? If so, in what version?
Matt
12-14-2007 11:14 AM
Hi Matt,
Still not fixed :( The CSCec41905 Bug/Feature request is still open.
Sorry man!
Rob
