install license on cisco router 2900 series
abd88elhak
18 Replies 18
Terry Cheema
If you have recived a PAK then register it on Cisco.com/go/license
You will receive license in an email. Copy to flash and use the below command to install the license.
license install flash0:XXX
Refer to detailed instructions here:
https://learningnetwork.cisco.com/docs/DOC-20321
Search for below:
How to get License from Cisco and how to install it in my Router ?
Installing Permanent License for feature set  (technology-package):
http://www.cisco.com/c/en/us/td/docs/routers/access/sw_activation/SA_on_ISR.html#pgfId-1097551
http://www.cisco.com/en/US/docs/routers/access/sw_activation/license_install_demo/license_install_
demo.swf (Video Demo)
Once you install the license, you already have active evaluation license and may not need a reload.
Run the command show version to verify the UC9 perm license is installed.
-Terry
Please rate all helpful posts.
Hi Terry,
I issued this command '  license boot module technology-package uck9 and after rebooting the router ,i saw the following
Technology Package License Information for Module:'c2900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security None None None
uc uck9 Evaluation uck9
data None None None
uck9 is in Evaluation but not permanent
how i change it from evaluation to permanent
On the other side of the coins,
I am having issues between my cme router and Mobile and remote access through expressway series
1.users from cme are able to see the MRA users but MRA users are not able to see CME users. They can hear but their video are disabled
There is no problem between cme user and another cme user.
I appreciate ur help
Refer below post to activate permanent license:
https://supportforums.cisco.com/document/111386/understanding-cme-srst-license-activation
Deepak
Thanks for the helpful link.It seems i have to purchase the permanent license from cisco. With the PAK and UDI ,i can download license file from the license portal.
That is correct you will need to purchase the permanent license from CCO using the PAK and UDI
Deepak
Ok.
Do you have an idea of how i can upgrade cme 8.0 (new 2900 router) to cme 10.5.The ios is version 15.1. I have read that ios versio 15.6 support cme 11.0 .How does one upgrade the cisco ios from 15.1 to 15.6.? is it by ordering the ios flash ?
Before you upgrade check the CME memory requirement .
http://www.cisco.com/c/en/us/support/unified-communications/unified-communications-manager-express/products-device-support-tables-list.html
(Rate if it helps)
JB
Hi Bhandari,
thanks for the response.I have checked the memory requirement and my router meets the requirement ? what's the process of upgrading to cisco ios software release of 15.6
thanks for your response
Download the 15.6 IOS from CCO and upload to the flash of IOS router.
conf t
no boot system
boot system flash:<name of 15.6 IOS file>
wr mem
reload
Reference:
http://www.cisco.com/c/en/us/support/docs/routers/3800-series-integrated-services-routers/49044-sw-upgrade-proc-ram.html
Deepak
OK.
I would try it.
Meanwhile can you help me with some cme challenges with cisco expressway. Have posted the issue in Cisco expressway forum but was refereed to cme post since the issue is associated with cme router
Is this the correct ios image? see attached,screen shot
i guess it is possible to copy ios image from one device (2911 router) to 2901 (router) via tftp server
Hello Deepak,
1)How do i back up my license file especially the permanent license for the uck9 to my tftp? I have just backed up the startup-config to the tftp server.I don't know if the license file is included
2) i have two cisco 2900 routers. One has the permanent license file  for uck9 installed .Is it possible to transfer this license file to the other? i think it might be possible through license host but i doubt if the two devices can have the license installed
Hi Deepak,
I have downloaded  the following ios c2900-universalk9-mz.SPA.156-3.M3.bin
I want to know if i will loose my uck9 license once i upgrade the ios
There will be no impact to the license file installed on the router when you upgrade the IOS image.
Deepak
