06-05-2015 04:00 AM - edited 03-17-2019 03:14 AM
08-03-2017 08:48 AM
thanks deepak
08-03-2017 11:48 AM
Hi Deepak,
would there be impact on the start-up-config file upgrade? I mean if i will loose my configuration cos am using vpn to log in
08-06-2017 11:47 PM
Hello deepak,
I am still waiting for your response to the question I asked previously. Would i loose my configuration file after the ios upgrade?
THanks for your response
06-05-2015 05:03 AM
First u need to generate the license file from ciso.com/go/license using PAK u got.You need to use UDI which u get using show version/show license udi
After u receive the license file , u need to upload .lic file in flash of router using commad copy tftp : flash: command.
Issue the license install flash:uck9_license.lic[assuming filename ] but the licenses are installed but not enabled. You need to enable technology license package i.e uck9.Issue command license boot module technology-package uck9
Accept it as YES and boot the router.
regds,
aman
