Install/Upgrade not finding files
keithlaws2004
I'm still working the install of the Chinese language pack and the server does not seem to want to find the Chinese locale cm-locale-zh_CN-7.0.1.3000-1.cop.sgn using the FTP search and CD ROM.  We are on CUCM 7.1.3 and this is the latest file I find for CUCM 7.  The search does find similar files such as cmterm-csf-copydialingrules-0.1.cop.sgn, but the drop down has none of the different locale files I've downloaded?  Has anyone else run into this issue?  Should it not be finding locale cm-locale-zh_CN-7.0.1.3000-1.cop.sgn for some other reason that I am unaware of?
Thanks!
Aaron Harrison
There is a newer version of that locale : cm-locale-zh_CN-7.1.3.2000-1.cop.sgn
Try that.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Aaron Harrison
Try that.
Aaron
That makes perfect sense!
Thank You!
Rob Huffman
Hey Keith,
Sorry about that my friend, my previous post was just an example
Like Aaron nicely noted (+5 "A"). here is the path for 7.1(3)
Cisco> Support>Tools and Resources> Software Downloads>  Voice and Unified Communications  > IP Telephony > Call Control> Cisco Unified Communications  Manager Version 7.1  > Unified Communications  Manager/CallManager Locale Installer > 7.1.(3.2000-1)  > cm-locale-zh_CN-7.1.3.2000-1.cop.sgn   >
Cheers!
Rob
