03-08-2019 05:37 AM
Attempting to add the 18-button KEM (CP-BEKEM) to a CP-8851. This is the first one of these KEMs in my system. CUCM 11.5.
At first, all I had was the BEKEM 36-Button expansion module available in the phone config. That kinda worked.
After adding the latest device pack I now have the CP-8800-Audio 28-button KEM available. My 18-button module won't even run with this one selected.
Is there supposed to be another module available?
Note, I'm relatively new at this, first time I've added a device pack. The process seemed to go well.
Thanks!
-John
Solved! Go to Solution.
03-08-2019 07:25 AM
If you have a 36 line KEM, you cannot choose the 28 line (audio or video) KEM, and expect it to work. Just as you cannot just use other phone model that does not correspond to the actual phone when you're configuring it.
03-08-2019 07:25 AM
03-08-2019 08:49 AM
