Integrate the Algo 8180 with your CUCM setup - Phones
shiva.nyalam
Step 1: Obtain Device Information
  • Find IP & MAC Address:
    • Once the Algo 8180 is connected to your network, access the device's web interface by entering its IP address in your web browser.
    • Typically, the default IP address is assigned by your DHCP server. You can check the IP address using a network scanner or via your router's connected devices list.
    • Log in to the web interface using the default credentials (usually found in the device manual), and note the MAC address.
Step 2: Configure CUCM
  • Add New SIP Trunk:
    • In CUCM Administration, navigate to Device > Trunk.
    • Click on Add New and select SIP Trunk.
    • Enter a descriptive name, select the appropriate Device Pool, and set the SIP Trunk Security Profile and SIP Profile.
    • Under Destination Address, enter the IP address of the Algo 8180 and the desired port (usually 5060).
Step 3: Add 3rd Party SIP Device (Algo 8180)
  • Configure the SIP Device:
    • Go to Device > Phone > Add New.
    • Select Third-Party SIP Device (Advanced).
    • Enter the MAC address of the Algo 8180.
    • Configure the Device Pool, SIP Profile, and Device Security Profile.
    • Save and apply changes.
Step 4: Set Up Directory Number
  • Assign Directory Number to Device:
    • Navigate to Call Routing > Directory Number > Add New.
    • Assign a unique Directory Number (DN) to the Algo 8180.
    • Set the Route Partition and other settings according to your requirements.
    • Save the configuration.
Step 5: Register Algo 8180
  • SIP Configuration on Algo 8180:
    • Access the Algo 8180's web interface.
    • Navigate to the SIP Settings section.
    • Enter the CUCM's IP address as the SIP Server.
    • Use the Directory Number as the SIP Username and set the corresponding Password.
    • Save the settings and reboot the device to register it with CUCM.
Step 6: Optional Multicast Configuration ( Not implemented in my setup )
  • Configure Multicast (for multiple speakers):
    • Go to the Advanced Settings in the Algo 8180 web interface.
    • Enable multicast and configure the IP address and port for multicast streaming.
    • Ensure that your network supports multicast and that other Algo devices are configured to receive multicast.
Jonathan Schulenberg
Not sure why you posted this. There isn’t a question, the instructions above are incorrect, and Algo already publishes config guides for CUCM on their website.
Thank you Jonathan, just recently implemented this device. Nice product and Easy setp with Cucm !!
