Integration CUCM with Fax server
Ben Yosef
Hi everyone,
I have CUCM 12.5 integrate with fax server via sip trunk.
When I'm trying to send fax through my mail it works just fine, but when I'm trying to receive a mail I'm getting an error.
The error is:
The CUCM send INVITE SDP(t38) to the fax server
The fax server return 488 Not Acceptable Here
Keeps happening until the CUCM send BYE message.
I'm attaching a capture of the flow from the side of the fax server.
Also the VGW is working on MGCP
CUCM IP - 172.17.16.107 (PUB-107, SUB-109)
Fax Server IP  - 172.16.0.97
Can you please help me with this.
remove "mgcp fax t38 nsf 000000" and try the below. Either alaw or Ulaw.
mgcp modem passthrough voip codec g711alaw
no mg
mg
Response Signature
6 Replies 6
Instead of t.38 try g711 passthrough. What fax server are you using ?
Response Signature
Hi, we are using FaxCore
I took the output from my VGW if it helps:
VGW-BneiBrak#sh running-config | section voice service voip
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
supplementary-service media-renegotiate
redirect ip2ip
signaling forward none
fax protocol pass-through g711ulaw
h323
mgcp call-agent 172.17.16.109 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp default-package fxr-package
mgcp bind control source-interface GigabitEthernet0/0/0
mgcp bind media source-interface GigabitEthernet0/0/0
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
ccm-manager fallback-mgcp
ccm-manager mgcp
no mg
mg
Response Signature
Ok I did change it, now I will try to check,
The SIP profile is regular? any special changes?
Thanks for your helping
Does your fax over IP server support t38 and if so have you configured/enabled it on the server?
Response Signature
Have a look at this old post, it looks to be a perfect match for your issue. https://community.cisco.com/t5/ip-telephony-and-phones/sip-based-fax-server-deployment/td-p/1371186
Response Signature
