Can I connect multiple voice gateways (CUBEs) in different locations over a network in an IP-to-IP configuration and connect an analog phone to each voice gateway using FXS ports to enable calls between the analog phones without using a call agent (call control)? By configuring VoIP dial-peers on the voice gateways and writing POTS dial-peers for each local analog phone connected to FXS ports, can the analog phones make calls between each other? I want to achieve this without using CME on the voice gateways, and the phones involved are not IP phones.
Topology should be like this
Analog phone connected over fxs>>>> Voice gateway>>>ip to ip trunk>>>>voice gateway>>>> FXS Over Phone>>>>
