Inter-site/building dial plan integration
J_Vansen_S
Level 3
Level 3
Hi All,
I need some pointers as to how do i need to build existing dialplan/pattern to integrate another site PABX with overlap extension.
We have on Main Building A existing PABX with Cucm + voice gateway(MGCP).
We need to integrate Building B so we can make calls to each other via dialing (8), all of building B calls is to be routed out to our Telco line.
1. Do i create a new CSS for Building B,
2. Create a Dial pattern of 8.1xx & 8.2xx & route to Building B
What about incoming calls from Building B, what do i need to configure in order for calls to be reachable to us & route calls out to our Telco
Appreciate any advise
From Site A to call Site B, there is no need to have another CSS. Since both A and B is using same dial plan, configure an extra digit as you said 8 before dialing site B.
So on Site A you need an RP with 8.[1-2]XXX and select the gateway device. The device which you use to connect the Site B. Use predot on RP  to strip the 8 before you send the call to Site B alcatel server.
For Site A to receive calls from site B (extension to extension calling) , on CUCM gateway configurations page use significant digit 4. And configure proper CSS.
If you want Site B to dial out PSTN using Site A IPT setup, don't use significant digit 4. on gateway allow all digit to pass.
One Site B to dial- Site A, AFAIK alcatel use trunk group configuration. configure a trunk group with 8.
Response Signature
