Intercluster trunk between cucm and cme
cigalahgroup
       I have CUCM 9.0 in my head officed  and CME 4.0 in BO. I have create the ICT from my CUCM and the call flow works fine form HO to BO.
               I  know CME doesnt supports Inter Cluster Trunk so I have to make the dial peer on the CME, can any one help me sharing the template how to do it ?
Ayodeji Okanlawon
Its very simple.
dial-peer voice 1 voip
decsription inbound dial-peer for calls from cucm
incoming called number.
no vad
dtmf-relay h245-alpha
dial-peer voice 2 voip
destination-pattern xxxx (where xxxx=your cucm extension pattern)
session target ipv4: y.y.y.y (where yyyy=cucm ip address
no vad
no vad
Please rate all useful posts
6 Replies 6
Ayodeji Okanlawon
Its very simple.
no vad
no vad
no vad
I dont understand why I have to make 2 Dial Peers.
no vad
no vad
Dial peer 1 is to receive the calls from CUCM and dial peer 2 is to send the calls to CUCM. If incase the call doesn't work after those configurations, please collect the following debugs Debug voice ccapi inout Debug h225 asn1 Debug h245 asn1
//Suresh Please rate all the useful posts.
When I am trying to put the command
Incorrect format for E.164 Number
        regular expression must be of the form  ^[][^0-9,A-F#*.?+%()-]*T?(\$)?$
Thanks it worked
Suresh Hudda
Don't forget to add h323-gateway voip bind srcaddr <ip address>  to the interface of CME.
Suresh
