Intermittant Calls failing on SIP Cube
c.walsh
Level 3
Level 3
   I have a customer who have a CUBE gateway installed & are experiencing intermittant incoming calls being dropped.
I believe the issue is with the SIP provider, but does anyone have any troubleshooting guides for reading the debug outputs on the CUBE Gateway.
thanks
Colin
mudmathu
Hey Colin,
Here is a config guide which tells the sip signalling in various scenarios ::
http://www.cisco.com/en/US/docs/ios/voice/sip/configuration/guide/sip_cg-msg_tmr_rspns.html#wp1056545
You can also give the results for some debugs and I can tell the cause of failure. Run the following debugs::
debug ccsip messages
debug voip ccapi inout
Please the results in the notepad file and give it to me for the failure call.
Mudit
