Showing results forĀ
Search instead forĀ
Did you mean:Ā
internal dialling in SRST mode
sky_voice
I have 10 digit DN's, I am trying to configure 3 digit internal dial translations, when in SRST mode.
e.g. phone registered as 123-4567-890 and someone internally dial as 890 it should go through...
I have tried to configure translation rules and tested it worked as expected. However when I applied it globally it didn't work.
I am missing some thread here or applying it incorrectly.
Rule:
voice translation-rule 5
rule 1 /^8..$/ /1234567&/
Profile
voice translation-profile internal1
  translate called 5
Applied globally:
voip-incoming translation-profile internal1
Thanks!
acampbell
Sky
Unhook your translation profile and try this instead
call-manager-fallback
dialplan-pattern 1 12345678.. extension-length 3 extension-pattern 8..
Now when in srst 806 is dialled it will call  the registered dn 1234567806
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
acampbell
Sky
Alex.
Hi Alex,
Great! +5 for this one.
I recollect I used the similar pattern in CME under telephony-service. However was unaware of such option in SRST.
Great help.
