Internal IP Phone Conference Call issue.
rajesh.kumar
Level 4
Level 4
We have CUCM version 8.6.2 on production.
We are facing issue with conference call within IP Phones.
All the IP phones are in same LAN and same Device Pool and same MRGL.
Once we try to add third call, call get disconnects with busy tone.
IP Phone Extensions  involved in conference call are.
IP Phone 3883 (initiate confierence)
IP Phone 3837
IP Phone 3815
All the phones are in same DP and MRGL.
Here I have attached MRG screenshot as well as CUCM SDI/SDL logs.
Pls. suggest
Rgds
Rajesh
avinsrid
Hi Rajesh,
Are we using software conference brigde? SW bridge can only talk g711.
If inter region codec default settins is g711 , then all phones will talk by default g711. Howrver, if CFB is in different region, we need to talk to CFB using g729 and that won't work. In thid case make the CFB have same region as ip phones or configure regions between phone and bridge to use g711? Or if you want bridge to talk g729, then use an ios based CFB.
Regards, Avinash
rajesh.kumar
Level 4
Level 4
Any suggestion ?
Rgds
Rajesh Kumar
Hi Rajesh,
I have looked at the traces and I could see below. The initial leg gets connected fine but the issue is when the extensions are dialling the BIB to join the conference. Have a look at the below traces.
#### DA FOR THE CALL 3833 to 3837 ####
10:55:03.492 |Digit analysis: match(pi="2", fqcn="3883", cn="3883",plv="5", pss="Uaq_Phones_PT:Fuj_Phones_PT:Global_Service_PT:Global_Loc_PT:Global_National_PT:Global_Mobile_PT:Global_TollFree_PT:VMPilotNumber_PT:AlAin_Phones_PT:Auh_Phones_PT:Dxb_Phones_PT:Musfa_Phones_PT:Rak_Phones_PT:Shj_Phones_PT:Ajm_Phones_PT:Global_International_PT", TodFilteredPss="Uaq_Phones_PT:Fuj_Phones_PT:Global_Service_PT:Global_Loc_PT:Global_National_PT:Global_Mobile_PT:Global_TollFree_PT:VMPilotNumber_PT:AlAin_Phones_PT:Auh_Phones_PT:Dxb_Phones_PT:Musfa_Phones_PT:Rak_Phones_PT:Shj_Phones_PT:Ajm_Phones_PT:Global_International_PT", dd="3837",dac="0")|3,100,56,1.46874070^10.28.35.45^SEP0017E045B068
10:55:03.492 |Digit analysis: analysis results|3,100,56,1.46874070^10.28.35.45^SEP0017E045B068
10:55:03.492 ||PretransformCallingPartyNumber=3883
|DialingPartition=Auh_Phones_PT
|DialingPattern=3837
|FullyQualifiedCalledPartyNumber=3837
|DialingPatternRegularExpression=(3837)
##### Now 3833 Calling 3815 ###
10:55:12.852 |Digit analysis: analysis results|3,100,56,1.46874165^10.28.35.45^SEP0017E045B068
10:55:12.852 ||PretransformCallingPartyNumber=3883
|DialingPattern=3815
|FullyQualifiedCalledPartyNumber=3815
|DialingPatternRegularExpression=(3815)
|DialingWhere=
10:55:12.853 |StationCdpc:    CcProceedReq - unicodeCallingPartyName='Khaled Ali Alhammadi' asciiCallingPartyName='Khaled Ali Alhammadi' callingParty='3883' unicodeCalledPartyName='Ashok Kunhithayil Divakaran' asciiCalledPartyName='Ashok Kunhithayil Divakaran' calledParty='3815'|3,100,56,1.46874165^10.28.35.45^SEP0017E045B068
### I see all three parties are dialling the BIB formed to join the Conf Call #####
10:55:16.513 |Digit analysis: analysis results|3,100,56,1.46874220^10.28.35.45^SEP0017E045B068
10:55:16.513 ||PretransformCallingPartyNumber=3883
|DialingPartition=
|DialingPattern=b00204922004
|FullyQualifiedCalledPartyNumber=b00204922004
|DialingPatternRegularExpression=(b00204922004)
10:55:16.532 |Digit analysis: match(pi="1", fqcn="3837", cn="3837",plv="5", pss="Uaq_Phones_PT:Fuj_Phones_PT:Global_Service_PT:Global_Loc_PT:Global_National_PT:Global_Mobile_PT:Global_TollFree_PT:VMPilotNumber_PT:AlAin_Phones_PT:Auh_Phones_PT:Dxb_Phones_PT:Musfa_Phones_PT:Rak_Phones_PT:Shj_Phones_PT:Ajm_Phones_PT", TodFilteredPss="Uaq_Phones_PT:Fuj_Phones_PT:Global_Service_PT:Global_Loc_PT:Global_National_PT:Global_Mobile_PT:Global_TollFree_PT:VMPilotNumber_PT:AlAin_Phones_PT:Auh_Phones_PT:Dxb_Phones_PT:Musfa_Phones_PT:Rak_Phones_PT:Shj_Phones_PT:Ajm_Phones_PT", dd="b00204922004",dac="0")|3,100,56,1.46874220^10.28.35.45^SEP0017E045B068
10:55:16.532 |Digit analysis: analysis results|3,100,56,1.46874220^10.28.35.45^SEP0017E045B068
10:55:16.532 ||PretransformCallingPartyNumber=3837
|DialingPartition=
10:55:16.557 |Digit analysis: match(pi="1", fqcn="3815", cn="3815",plv="5", pss="Uaq_Phones_PT:Fuj_Phones_PT:Global_Service_PT:Global_Loc_PT:Global_National_PT:Global_Mobile_PT:Global_TollFree_PT:VMPilotNumber_PT:AlAin_Phones_PT:Auh_Phones_PT:Dxb_Phones_PT:Musfa_Phones_PT:Rak_Phones_PT:Shj_Phones_PT:Ajm_Phones_PT", TodFilteredPss="Uaq_Phones_PT:Fuj_Phones_PT:Global_Service_PT:Global_Loc_PT:Global_National_PT:Global_Mobile_PT:Global_TollFree_PT:VMPilotNumber_PT:AlAin_Phones_PT:Auh_Phones_PT:Dxb_Phones_PT:Musfa_Phones_PT:Rak_Phones_PT:Shj_Phones_PT:Ajm_Phones_PT", dd="b00204922004",dac="0")|3,100,56,1.46874220^10.28.35.45^SEP0017E045B068
10:55:16.557 |Digit analysis: analysis results|3,100,56,1.46874220^10.28.35.45^SEP0017E045B068
10:55:16.557 ||PretransformCallingPartyNumber=3815
|DialingPartition=
###### Finally the call is getting disconnected due to Media Resource allocation failure ####
10:55:16.574 |GenAlarm: AlarmName = MediaResourceListExhausted, subFac = CALLMANAGERKeyParam = , severity = 4, AlarmMsg = MediaResourceListName : MRGL_SUB1_SUB2_PUB
MediaResourceType : 2
AppID : Cisco CallManager
ClusterID : StandAloneCluster
NodeID : CUCMSUB2
10:55:16.574 |MediaResourceManager::waiting_MrmAllocateXcoderResourceReq - CI=63262643, Count=1|3,100,56,1.46874220^10.28.35.45^SEP0017E045B068
10:55:16.574 |MediaResourceManager::sendAllocationResourceErr - ERROR - no transcoder device configured|3,100,56,1.46874220^10.28.35.45^SEP0017E045B068
10:55:16.575 |!!ERROR!! -MediaManager-(238915)::disconnOnResourceAllocationFailure, ERROR  disconnOnResourceAllocationFailure - fails to allocate MTP/XCoder,connCount=2|3,100,56,1.46874220^10.28.35.45^SEP0017E045B068
Further all the CI are getting disconnected one by due to to reource issue. Please check the Region setting between the phones and the resources and see if the Xcoder is required do you have it in the MRGL and test....
Please rate if helpful !!
Cheers,
Ankit
avinsrid
Hi Rajesh,
Regards, Avinash
A brief, crisp and solid input.
Thanks a lot Avinash !
