INTERNAL MOH IN CISCO CME
ali nasser
HI,
I HAVE CME VERSION 4.1 I NEED TO ACTIVET THE MOH IN INTERNAL CALLS, I UPLOAD THE FILE IN FLASH AND I DO THE CONFIGURATION BUT ITS NOT WORKING ITS JUST WORKING FROM PSTN CALLS.
IF ANY ONE HAVE THE CONFIGURATION PLS SEND IT TO ME.
REGARDE TO EVERYONE.
ALI NASSER
Jaime Valencia
Configuring Music on Hold from an Audio File
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucme/admin/configuration/guide/cmemoh.html#wp1010384
Review step 5
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
5 Replies 5
Jaime Valencia
Review step 5
java
java
This Link isn't available any more, so please can you post a Link with the same information on it?
thomas
Just remove /partner from the link.
Note; usually internal callers will get annoyed soon to have to listen to music when a coworker places them on hold.
Thank you
Thank you for the nice rating and good luck!
