Showing results forĀ
Search instead forĀ
Did you mean:Ā
International Dial Plan for GB latest update
Alan Singmin
Hi there,
I need to update the Dial Plan for Great Britain to include dialing to numbers beginning with 0204 and any other new numbers for the UK
The latest one on the Cisco site is 3-1-35.GB
If I look at the flat file I can  see that this latest version also won't allow dialing to 0204 numbers
# 0+20+[01378]XXXXXXX
P: 0 NATIONAL-ACCESS
P: 20 AREA-CODE
P: [01378]XXXXXXX SUBSCRIBER
T: N
C: LONGDISTANCE
E: +,[COUNTRY-CODE],AREA-CODE,SUBSCRIBER
F: NATIONAL-ACCESS,AREA-CODE,SUBSCRIBER
S: Y
Where can I get the latest update that will allow dialing to 0204 and other newer numbers (if any)?
Many thanks in advance
Alan
Jaime Valencia
The only place is the downloads area from cisco.com as they're cop files and are signed.
If there have been changes and no new dial plan has been released, I'd reach out to your SE to discuss this
java
if this helps, please rate
In the meantime, just build a Route Pattern for other desired pattern manually as a workaround. Thatā€™s all the IDP files do anyway, behind the scenes.
