IOS for 2921 for voice support
Hi all,
we bought new router cisco 2921 with the ios ipbase c2900-universalk9-mz.SPA.151-4.M2.bin but no voice commands are working on that.
i searched cisco site but could not find any ios for 2921 which supports voice.
can any one guide me please.....Thanks in advance.
13 Accepted Solutions
Ayodeji Okanlawon
You should use the "universal" one..something like this
c2900-universalk9-mz.SPA.151-4.M5.bin
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
The answer to that question is to use the cisco feature navigator tool to see if the feature you are trying to use is supported in that ios.
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
The second thing is that that IOS is what I am using i my production network and I am 100% it supports voice. What command are you trying to use or what voice feature are you trying to configure
I am sure this will work. The question is what command did you enter that is showing as not supported..We use the universal image on our Main Production CUBES.
The first thing is this..send the ff:
sh inventory
sh diag
We will see if your pvdm is seen by the router
Did you try the command like this..
voice-card 0
dspfarm
dsp services dspfarm
Do you have VWICs on the router?
If you have Vwics on the router have you configured the card type for them
card type {t1 | e1}
Do you have the voice license for the router?
Does "show license" command have the following:
Index 3 Feature: uck9
Period left: Life time
Yes you can. You dont need VWICs for ip connectivity. You can just use any of your gig interfaces to connect to your ITSP. I am just wondering why you cant enter the command voice-card 0
Can you send the output and the error you get
Yes. The voice commands are not available without the voice license.
UC license PAK should be available from any Cisco resaler.
The bundled router part number is CISCO2921-V/K9 or C2921-CME-SRST/K9 (with SRST).
License model for 2800 series routers and 2900 serires is very different and not transferable.
Hi Asif,
If u want to use Cisco 2921 router with PVDM installed for Voice , u need to have Voice License activated which could be done either through Evaluation mode or purchase them.
For evaluation mode, u need to visit cisco.com/go/license and generate the license using serial number of cisco 2921 router and UDI . The same license file has to be uploaded in flash of router through TFTP server and activated by using commands
license boot module module-name technology-package package-name and .license accept end user .
Reboot the router.
At least u can check your config and working in Eval mode for 60 days..
regds,
aman
24 Replies 24
Ayodeji Okanlawon
thank you aokanlawon,
i downloaded the ios    "c2900-universalk9-mz.SPA.153-1.T.bin" its also not working.
how can i know that "c2900-universalk9-mz.SPA.151-4.M5.bin"   is voice supported ios.
this i am planning to use as voice gateway for our branch office connecting to call manager at head office.
we got new sip line from itsp and mpls.
i installed pvdm 3-32 on the router.
and  tried to issue voice card 0 and dspfarm commands but none are working on that.
i have to configure sip line and dialpeers for branch
sh inventory
sh diag
the pvdm can be seen in sh diag and inventory
PVDM Slot 0:
        32-channel (G.711) Voice/Fax PVDM3 DSP DIMM PVDM daughter card
        Hardware Revision        : 1.0
        Part Number              : 73-11577-03
        Board Revision           : C0
        Deviation Number         : 0
        Fab Version              : 03
        PCB Serial Number        : FOC164675E5
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Processor type           : 00
        Product (FRU) Number     : PVDM3-32
        Version Identifier       : V01
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF 40 05 D9 41 01 00 82 49 2D 39 03 42 43 30
          0x10: 88 00 00 00 00 02 03 C1 8B 46 4F 43 31 36 34 36
          0x20: 37 35 45 35 03 00 81 00 00 00 00 04 00 09 00 CB
          0x30: 8F 50 56 44 4D 33 2D 33 32 20 20 20 20 20 20 20
          0x40: 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF FF FF
          0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Embedded Service Engine 0/0 :
  Total platform memory : 524288K bytes
  Total 2nd core memory : 0K bytes
  Start of physical address for 2nd core : 0x80000000
  Virtual address start of 2nd core memory : 0x0 - 0x0
  2nd core configured disabled
  L2 cache ways for 2nd core : 0
yourname#sh inventory
NAME: "CISCO2921/K9", DESCR: "CISCO2921/K9 chassis, Hw Serial#: , Hw Revision: 1.0"
PID: CISCO2921/K9      , VID: V05 , SN:
NAME: "PVDM3 DSP DIMM with 32 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 32 Channels"
PID: PVDM3-32          , VID: V01 , SN:
NAME: "C2921/C2951 AC Power Supply", DESCR: "C2921/C2951 AC Power Supply"
PID: PWR-2921-51-AC    , VID: V02 , SN:
voice-card 0
dspfarm
yes
exactly.....
card type {t1 | e1}
there are no vwic cards present on the router
can't i connect the sip line to gig wan interface card.
