IOS H323 Gateway / CUCM with Egyptian numbering plan...
Hi All
Does anyone have an example of this config ?
We have to deploy remotely a Cisco IOS H323 Gateway (ISR2921) linked to a CUCM V9.1, with the Egyptian numbering plan in CAIRO, gateway which has to be SRST of course !
May I have your help ?
Best regards,
Christian.
helawamry
Hi Chris,
you will configure h323 under interface reachable to CUCM
interface GigabitEthernet0/0
ip address x.x.x.x 255.255.255.0
duplex auto
speed auto
h323-gateway voip bind srcaddr "cucm ip add"
then dial-peers
dial-peer voice 1 pots
incoming called .
direct-inward-dial
port xxx
dial-peer voice 2 voip
destination-pattern "cisco ip phone extension"
session target ipv4: x.x.x.x "CUCM ip add"
dtmf-relay h245-alphanumeric h245-signal
codec g711ulaw
no vad
dial-peer voice 3 po
destination-pattern 9[234].......  "local calls inside cairo"
port xxx
dial-peer voice 4 po
destination-pattern 90[3-9]T  "nationals calls from cairo to long distance"
prefix 0
port xxx
dial-peer voice 5 po
destination-pattern 901[012]T  "Mobile calls "
prefix 01
port xxx
SRST configuration
Telephony-ser
ip sour x.x.x.x "ip add of the router connected to ip phones"
srst mode prov all
max-dn 100
max-ep 100
secondary tone 9
system message "connection to HQ down"
this is simple confiugration of H323 with SRST.
Let me know if you need more info
Helawamry
helawamry
Hi Chris,
duplex auto
speed auto
then dial-peers
incoming called .
direct-inward-dial
port xxx
codec g711ulaw
no vad
port xxx
prefix 0
port xxx
prefix 01
port xxx
SRST configuration
Telephony-ser
srst mode prov all
max-dn 100
max-ep 100
secondary tone 9
Helawamry
Hi Halawamry !
Hope you are doing well...
Thank you very (very) much for your help, this will simplify my configuration (and reassure me too!)
Ch.
