09-20-2018 02:20 AM
Hi All,
We hit the below error on ISR 4300 for which we have upgraded to the fixed version based on the bug details :
Aug 6 2018 00:35:45.248 AEST: MCPRP-QFP-ALERT: Slot: 0, QFP:0, Load 0% recovered.
Aug 6 2018 04:24:40.439 AEST: MCPRP-QFP-ALERT: Slot: 0, QFP:0, Load 908431794% exceeds the setting threshold(80%).
Aug 6 2018 04:24:45.438 AEST: MCPRP-QFP-ALERT: Slot: 0, QFP:0, Load 0% recovered.
Aug 6 2018 04:27:30.456 AEST: MCPRP-QFP-ALERT: Slot: 0, QFP:0, Load 902970710% exceeds the setting threshold(80%).
Aug 6 2018 04:27:40.458 AEST: MCPRP-QFP-ALERT: Slot: 0, QFP:0, Load 0% recovered.
Bug :
CSCvh16478 - CSR1000v: invalid QFP load calculation (Recommit CSCvg92754)
(https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvh16478)
After the upgrade to 16.06.03 version again we are facing a different error on the IOS console . Could anyone please suggest on the same / or is that we can avoid through some config settings?
Sep 20 01:20:43.321: %PLATFORM-4-ELEMENT_WARNING: SIP1: smand: RP/0: Used Memory value 89% exceeds warning level 88%
Sep 20 01:30:53.334: %PLATFORM-4-ELEMENT_WARNING: SIP1: smand: RP/0: Used Memory value 89% exceeds warning level 88%
Sep 20 01:41:03.349: %PLATFORM-4-ELEMENT_WARNING: SIP1: smand: RP/0: Used Memory value 89% exceeds warning level 88%
Sep 20 01:51:13.350: %PLATFORM-4-ELEMENT_WARNING: SIP1: smand: RP/0: Used Memory value 89% exceeds warning level 88%
Sep 20 02:01:23.368: %PLATFORM-4-ELEMENT_WARNING: SIP1: smand: RP/0: Used Memory value 89% exceeds warning level 88%
Thanks In Advance!
09-20-2018 02:33 AM
Sounds similar to another bug: Memory leak under cpp_cp_svr process CSCvf52877
It has been fixed in more fresh release:
04-08-2019 01:56 PM - edited 04-08-2019 01:57 PM
Seeing the error in Cisco IOS Software [Everest], ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.6.5, RELEASE SOFTWARE (fc3) - Cisco ISR4331/K9
%PLATFORM-4-ELEMENT_WARNING: SIP1: smand: RP/0: Used Memory value 91% exceeds warning level 88%
Message repeats every 10 minutes
01-09-2019 12:56 AM
I having this logs on cisco ASR1002. Is there any impacts when this memory errors alerted? Is there any Known Fixed Releases: ?
Kindly advise.
Cisco IOS Software, IOS-XE Software (PPC_LINUX_IOSD-ADVIPSERVICESK9-M), Version 15.3(1)S1
*Jan 9 08:38:28.800: %PLATFORM-4-ELEMENT_WARNING: R0/0: smand: ESP/0: Committed Memory value 92% exceeds warning level 90%
