IOS UPGRADATION IN CUCM CLUSTER VER 7.1.5b(Su5)
Sandipan Khatke
HI ,
I am going to upgrade CUCM IOS ver from 7.0.2.20000-5 up to 7.1.5b(Su5) . but at customer end two CUCM is configured in Cluster .
about this activity i have some queries as follows .
1) I am don't know the IOS up gradation procedure . kindly share any document .
2) There is any chance to crash , when i am start the uploading ios in CUCM Publisher , it is directly affect on both publisher & subscriber .
     after uploading IOS in publisher it is automatically synchronize with subscriber if yes plz let me HOW ??
    otherwise required to follow  the same ios uploading process as publisher in subscriber .
BR ,
Sandipan .
5 Replies 5
1) check if your hardware can go to 7.1.5
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/7_1_5/cucm-rel_notes-715.html#wp579941
2) Check that you can go direct from 7.0.2 to 7.1.5
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr1.pdf
Then below is the proccess
Upgrade first Pub (do not switch version when completed)
Upgrade second Subs (do not switch version when completed)
Then go to Pub - Switch version (wait until completed)
Then Subs - switch version
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
Hi ,
thanks for your response ..
But i have one query i.e how i can configure radius in cucm other can i create user in cucm by default I have accessing through admin .
BR ,
SANDIPAN
You can integrate cucm (PUB) , with ldap/active directory
Then when the integration succeed and the users are in the cucm you can go to end user and assign roles to the administration guy(like super user in the role group.Is down of the end user tab
Follow this doc
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_1_2/ccmcfg/b02ldaut.html
Is the same with 7.1.5 version
chrysostomos
Ayodeji Okanlawon
Sandipan,
Please do not take this as a personal attack on you, but I highly recommend that you get someone who is skilled at doing this to perform the upgrade. Many things can go wrong and if you do not know what to do, it is going impact everybody.
You can build a lab cucm in Vmware to learn about cucm and and perform similar tasks as upgrades, but I suggest not to do so on a production environment unless you know what you are doing...
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
    Thank you Chrysostomos &  Aokanlawon for your support !
I have never think for accepting such types of challenge were your support when with me , I got some document for up gradation IOS Procedure in CUCM .
Thanks alot for your support & your suggestion
BR ,
Sandipan .
