IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6332 Views
  • 14 replies
when we connect pc to Ip phone on the pc port computer is geting 160. Ip address and I pphone is working good but not computer.when we connect computer to same port it is working fine.interface GigabitEthernet2/0/17switchport access vlan 2switchport ...
In "enterprise parameters configuration", you can't choose which server you select, so I know the parameters are cluster-wide. But in "service parameter configuration", you have to choose which server. Does that mean the parameters are only applied t...
Oak Ridge by Level 1
  • 622 Views
  • 2 replies
