09-26-2011 03:13 PM - edited 03-16-2019 07:11 AM
I have an IP phone 7940 and I just switched service providers and I can not figure out how to unlock my network configuration. I can not find a button or area on the menu where I can access the unlock function. Any suggestions?
Solved! Go to Solution.
09-27-2011 11:13 PM
09-26-2011 04:21 PM
Is the phone SIP or SCCP?
If SIP you need your phone password.
If SCCP, use key sequnce **#**
09-27-2011 04:34 AM
Udit - thanks for the info. I did the **#** and it reset so it must be a SCCP. The network configuration is locked and I don't know how to unlock it. I have not found a way to access the unlock function. Do you know how to do that?
09-27-2011 07:00 AM
Hi Brad, may be you need to reset the ip phone to the factory default.
hth
In order to perform a factory reset a phone, complete these steps:
Unplug the power cable from the phone, and then plug in the cable again.
The phone begins its power up cycle.
Immediately press and hold # and while the Headset, Mute, and Speaker buttons begin to flash in sequence, release #.
The Headset, Mute, and Speaker buttons flash in sequence in order to indicate that the phone waits for you to enter the key sequence for the reset.
Press 123456789*0# within 60 seconds after the Headset, Mute, and Speaker buttons begin to flash.
If you do not complete this key sequence or do not press any keys, after 60 seconds, the Headset, Mute, and Speaker buttons no longer flash, and the phone continues with its normal startup process. The phone does not reset.
If you enter an invalid key sequence, the buttons no longer flash, and the phone continues with its normal startup process. The phone does not reset.
If you enter this key sequence correctly, the phone displays this prompt:
Keep network cfg? 1 = yes 2 = no
In order to maintain the current network configuration settings for the phone when the phone resets, press 1. In order to reset the network configuration settings when the phone resets, press 2.
If you press another key or do not respond to this prompt within 60 seconds, the phone continues with its normal startup process and does not reset. Otherwise, the phone goes through the factory reset process.
09-27-2011 11:13 PM
My bad. **#** is a reset sequence.
Unlock sequence is just **#
09-28-2011 04:14 AM
Thank you for your help Udit.
