IP communicator 8
Saima Harris
Can IP communicator V8 or any other version be installed on terminal server for users.
Does it support terminal Server
Saima
Jaime Valencia
Note
Cisco IP Communicator is not supported  in VMWare, Citrix, Terminal Services, Remote Desktop or other thin  client environments.
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cipc/8_5/english/release_notes/CIPC8x_RN.html
EDIT: and no, there's no IPC version which is supported on any of the above scenarios.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Thank you for your quick response
