IP communicator and vpn client for MS windows 7
lesterccna
Hi Engineer,
is there ip communicator software that compatible with microsoft windows 7 and cisco vpn client?
thanks in advance.
regards,
lester
Brandon Svec
Level 7
Level 7
Some info here:
http://lmgtfy.com/?q=cipc+windows+7
"Re: VPN and CIPC in 64 bit -- any solutions coming soon?
CIPC works fine in x64 Vista and Windows 7 except for the CDP driver ( you will get an error every time you open it) and that only really matters in Enterprise Deployments with Emergency Responder. It installs fine and no workarounds are necessary"
-- please remember to rate and mark answered helpful posts --
I'm running CIPC under Windows 7. We have the CDP service disabled, so that's not a problem.
The problem I'm facing is I'm not able to configure the headset for mic and speaker (default device is the only option), but I am able to change the setting for the ring value. Is there a fix for this, or do we have to wait for Windows 7 support.
