IP Communicator is not getting registered with CUCM..
harish9211
When um trying to register my ip phone with CUCM its showing "Configuring IP"...for long tym..
What can be the problem while registering.
Thanks and Regards,
Harish
10 Replies 10
acampbell
Have configured the IPC to use the correct ip addresses for the TFTP and the Call processors servers
Alex
Regards, Alex. Please rate useful posts.
Hi Alex,
Um giving CUCM ip as TFTP ip in IPC.
Thanks and Regards,
Harish
abarkalg
Hi Harish,
                Are you getting the IP from the DHCP ? did you try giving the IP manually and check if it can be registered?
Abdul Sattar
Hi Abdul,
No um not using DHCP. I m giving ip manually.
Actually i have installed CUCM on vmware and by using gns3 um trying to register ip communicator with CUCM but its showing "Configuring IP"........
Thanks and Regards,
Harish
Can the PC running IPC actually ping the CUCM ip address (TFTP)?
I'd start there.
Ven
Ven Taylor
Hi Ven,
Yes i can ping from the PC where IPC is installed...
Thanks and Regards,
Harish
OKay.  Let's run down the process.
If you can ping the tftp server (publisher) can you check the CUCM and make sure the appropriate services are running?
Go to the Unified Serviceability page, choose the server, and check to see tftp service is running.
Are there any other devices that can register to the CUCM?
Ven
Ven Taylor
Hi Ven,
Yes Ven tftp service is running its status is "Activated"....
n yes i have registered one gateway with CUCM and it got registered successfully....
Thanks and Regards,
Harish
Hi All,
Please suggest some solution for this...plzz...
Thnks & R's
Harish
Please go to your IPC, click on Menu (button next to the minimize button - on top right), go to preferences, go to Network, then check under device name which network card from your pc the IPC is using.
then double check if this is the correct configured MAC address you have configured on cucm.
