IP Phone 6901 Setup by private Customer
Hello everyone. I, as a private final user, bought 3 new 6901 IP Phones off ebay, thinking I would be able to set them up by myself and use the as IP doorbell receivers. Once I got them, I tried to configure them (hoping for an IP based local webpage) and discovered that I needed Cisco software to do that (don't I?). Since I am a private user, I don't have any partnership with Cisco, which means I'm not allowed to download the software and proceed. What am I supposed to do then? Should I resell the phones? Is there any way a private can access the configuration page for his terminals by himself??
Thank you very much,
Alex Tischer
3pcc software is available only  with 78xx and 88xx series.
Response Signature
Jaime Valencia
Search the community for threads on how to configure phones with 3rd party PBX and you'll get all you need, the phones that have a config GUI are 3PCC models which is not an option for the model you got, so avoid threads that discuss 3PCC phones as that's not applicable to you.
java
if this helps, please rate
Thank you for your rapid answer. Fact is that I don't have a PBX, since I don't have a telephone line. I wanted to use the terminals just to communicate to a 2N doorbell (doorbell ring, audio, door open signal)
Phones are dumb endpoints, they need a PBX / call control agent for the dial plan and to place calls. 3PCC can be configured to place a direct call using the IP, but not the ones you got, for those you need a PBX.
java
