02-13-2014 12:20 PM - edited 03-16-2019 09:44 PM
Hi all!
I'm looking for phones that support SPANless call recording.
Does anyone know whether the phones 7821 has built in bridge or not ?
Thanks!
Solved! Go to Solution.
02-13-2014 01:42 PM
You can find that out in your CUCM, go to reporting, CM feature list, and run the report for BIB.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
02-13-2014 01:42 PM
java
02-13-2014 10:55 PM
Hi Jaime,
[+5] good thing to know.
regds,
aman
02-14-2014 03:21 AM
Thank you! It's exactly what I needed.
But took some time, because i didn't have support for 7800 series phones in my CUCM
Anyway, for anyone who is interesting:
Cisco 6911,6921,6941,6945,6961,7906,7911,7921,7925,7926, 7931,7937,7940,7941 ,7941G-GE,7942,7945,7960,7961,7961G-GE,7962,7965,7970.7971,7975,8941,8945, IP Communicator - SCCP Built In Bridge
Cisco 3905,3911,3951,6911,6921,6941,6945,6961,7821,7841, 7861,7905,7906,7911 ,7912,7931,7941, 7941G-GE,7942,7945,7961,7961G-GE,7962,7965,7970,7971,7975 ,8831,8941,8945,8961,9951,9971 - SIP Built In Bridge
Cisco ATA 187 SIP Built In Bridge
Cisco Cius SIP Built In Bridge
Cisco Cius SP SIP Built In Bridge
Cisco DX650 SIP Built In Bridge
Cisco IP Communicator SIP Built In Bridge
Cisco Unified Client Services Framework SIP Built In Bridge
Universal Device Template SIP Built In Bridge
04-25-2016 08:18 PM
04-25-2016 08:23 PM
The report will only come back with phones that are compatible with your system, 8845 requires 10.5(2) to work, it will not show up in your report if you're using 10.5(1)
06-21-2015 04:45 AM
Thanks.....
