IP Phone 7821 BIB
Hi all!
I'm looking for phones that support SPANless call recording.
Does anyone know whether the phones 7821 has built in bridge or not ?
Thanks!
Jaime Valencia
You can find that out in your CUCM, go to reporting, CM feature list, and run the report for BIB.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
6 Replies 6
Jaime Valencia
java
java
Hi Jaime,
[+5] good thing to know.
regds,
aman
Thank you! It's exactly what I needed.
But took some time, because i didn't have support for 7800 series phones in my CUCM
Anyway, for anyone who is interesting:
Cisco 6911,6921,6941,6945,6961,7906,7911,7921,7925,7926,          7931,7937,7940,7941          ,7941G-GE,7942,7945,7960,7961,7961G-GE,7962,7965,7970.7971,7975,8941,8945, IP Communicator           - SCCP          Built In Bridge
Cisco 3905,3911,3951,6911,6921,6941,6945,6961,7821,7841,          7861,7905,7906,7911          ,7912,7931,7941,          7941G-GE,7942,7945,7961,7961G-GE,7962,7965,7970,7971,7975          ,8831,8941,8945,8961,9951,9971 - SIP          Built In Bridge
Cisco ATA 187          SIP          Built In Bridge
Cisco Cius          SIP          Built In Bridge
Cisco Cius SP          SIP          Built In Bridge
Cisco DX650          SIP          Built In Bridge
Cisco IP Communicator          SIP          Built In Bridge
Cisco Unified Client Services Framework          SIP          Built In Bridge
Universal Device Template          SIP          Built In Bridge
Does 8845 have Built-in-bridge?
I have just run the report from CUCM 10.5.1, 8845 is not there.
Or maybe the model is too new?
The report will only come back with phones that are compatible with your system, 8845 requires 10.5(2) to work, it will not show up in your report if you're using 10.5(1)
java
Thanks.....
