09-24-2015 06:25 AM - edited 03-17-2019 04:23 AM
Sometimes my Ip Phones 7821 are showing in Display an message thay says Service Domain. When i reset this Phone, it returns properly. The switches that Phones attached are HP.
What I have to do?
Solved! Go to Solution.
09-24-2015 07:15 AM
I get the point that you don't have expressway, but the phones' firmware assumes that you may use MRA hence it allows you to define it. Are you on latest firmware as these phones have and continue to have lots of bugs, so I would suggest updating to latest available firmware.
09-24-2015 07:07 AM
I believe this has to do with Expressway, as these phones are capable of registering to CUCM across Expressway (MRA).
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/7811-7821-7841-7861/10-1/english/userguide/PA2D_BK_7A9531A8_00_7811-7821--7841--7861-ug-cucm/PA2D_BK_7A9531A8_00_7811-7821--7841--7861-ug-cucm_chapter_0111.html
Not sure if that message pop-up, perhaps the phone loses connection to CUCM server and tries to connect across MRA.
09-24-2015 07:12 AM
In this case is not Expressway, because I don't have it here. Ip Phones and CUCM are connect "directly" by L2 and L3.
09-24-2015 07:15 AM
09-24-2015 07:37 AM
Is there a way to "turn-off" Sign-in?
