ip phone 7900 series (7945 - 7965 - 7911) doesn't log missed call
I've the problem in  some phone (with different model ) . Some phones device dosen't log the missed calls. The version of the CUCM is 8.6.2.22900-9 .
what can I do?
thanks a lot .
Roberto
V.Naveen Kumar
Check firmware version for all phones..
if it is old version. plz upgrade to new firmware version
below are latest version:
For 7945/7965:cmterm-7945_7965-sccp.9-3-1SR1-1.cop.sgn
For 7911:cmterm-7911_7906-sccp.9-3-1SR1-1.cop.sgn
Jonathan Schulenberg
There is a checkbox on the DN Configuration page: Log missed calls. Is it unchecked on the line appearences where this isn't happening?
Please remember to rate helpful responses and identify helpful or correct answers.
someone have a good idea to resolve tftp problem?
Thanks for your support but your suggest I have just try. After some test I have understand that the problem is PUBLISHER tftp SEVICES.. When the phone is registered AND set tftp subscriber the problem don't see. The CUCM1 (PUBLISHER) don't work the TFTP(the service is started) but don't work. For example when I connect new phone 7911 with the old firmware (9-0-2), the phone is registered but dosen't change the new firmware into the cucm(9-2-3). If I force hardware reset factory , the phone download only term06.default.
can you help me, please?
Thanks a lot.
