ip phone 7905 dosen't advertise codecs g711ulaw and g711 alaw
denis.moiseenko
Hello!
Could you please help me!
I have cisco ip phone 7905 it's registered ont the CUCM and I try to call from this phone to PSTN. When CUCM advertises the supported codecs it's only advertises G729 codec but my ITSP dosen't support this codec. As I know the ip phone support g711ulaw and g711 alaw. Why this codec dosen't advertise by CUCM. What may be the problem?
and also here the debug ccsip message
Jun  4 05:52:54.237: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:93.190.xx.xx SIP/2.0
Via: SIP/2.0/UDP 93.190.xx.xxx:5060;branch=z9hG4bK5b861b74;rport
From: "asterisk" <sip:asterisk@93.190.xx.xx>;tag=as0b1aa8f0
To: <sip:93.190.xx.xx>
Contact: <sip:asterisk@93.190.xx.xx>
Call-ID: 1e852b0e25f4ec48467e666c3101c23f@93.190.xx.xx
CSeq: 102 OPTIONS
User-Agent: Asterisk PBX
Max-Forwards: 70
Date: Tue, 04 Jun 2013 05:52:54 GMT
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY
Supported: replaces
Content-Length: 0
Jun  4 05:52:54.257: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 93.190.xx.xx:5060;branch=z9hG4bK5b861b74;rport
To: <sip:93.190.xx.xx>;tag=E79D320-4D7
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 102 OPTIONS
Supported: 100rel,replaces
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, COMET, REFER, SUBSCRIBE, NOTIFY, INFO, UPDATE, REGISTER
Accept: application/sdp
Allow-Events: telepho
sochi-gw#ne-event
Content-Length: 167
Content-Type: application/sdp
v=0
o=CiscoSystemsSIP-GW-UserAgent 9934 5563 IN IP4 93.190.xx.xx
s=SIP Call
c=IN IP4 93.190.xx.xx
t=0 0
m=audio 0 RTP/AVP 18 0 8 4 2 15 3
sochi-gw#
Jun  4 05:52:56.333: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:89881634594@192.168.228.1:5060 SIP/2.0
Via: SIP/2.0/TCP 192.168.21.3:5060;branch=z9hG4bK1c83f425e92ac2
From: <sip:2965873@192.168.21.3>;tag=2471146~96ef6ccc-73f3-4efb-a1b9-3c908a715a62-28044735
To: <sip:89881634594@192.168.228.1>
Date: Tue, 04 Jun 2013 05:52:56 GMT
Call-ID: ffb57180-1ad180b8-127478-315a8c0@192.168.21.3
Supported: timer,resource-priority,replaces
Min-SE:  1800
User-Agent: Cisco-CUCM9.1
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence, kpml
Supported: X-cisco-srtp-fallback,X-cisco-original-called
Call-Info: <sip:192.168.21.3:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Cisco-Guid: 4290081152-0000065536-0000084914-0051751104
Session-Expires:  1800
P-Asserted-Identity: <sip:2965873@192.168.21.3>
Remote-Party-ID: <sip:2965873@192.168.21.3>;party=calling;screen=yes;privacy=off
Contact: <sip:2965873@192.168.21.3:5060;transport=tcp>
Max-Forwards: 70
Content-Length: 238
v=0
o=CiscoSystemsCCM-SIP 2471146 1 IN IP4 192.168.21.3
s=SIP Call
c=IN IP4 192.168.21.3
b=TIAS:8000
b=AS:8
t=0 0
m=audio 25426 RTP/AVP 18 101
a=rtpmap:18 G729/8000
a=ptime:20
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
Jun  4 05:52:56.361: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 488 Not Acceptable Media
To: <sip:89881634594@192.168.228.1>;tag=E79DB54-2191
CSeq: 101 INVITE
Warning: 304 192.168.18.9 "Media Type(s) Unavailable"
Allow-Events: telephone-event
Content-Length: 0
sochi-gw#
Jun  4 05:52:56.449: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:89881634594@192.168.228.1:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Thank you in advance!
Gergely Szabo
Post the phone config and the dialpeer config.
You may want to force the codec, using the codec command under the phone config.
G.
Sent from Cisco Technical Support Android App
here the phone config
true
SCCP
true
2012c
tzupdater.jar
000000
Off
Disabled
false
DP-CPT-SOCH
CMLocal
D.M.Y
Etc/GMT-4
192.168.15.10
Directed Broadcast
192.168.15.11
Directed Broadcast
192.168.21.7
Directed Broadcast
CUCM-SPB-CLUSTER
true
cucm2
cucm2
2000
5060
5061
2427
2428
cucm2
cucm1
cucm1
2000
5060
5061
2427
2428
cucm1
SRST-SOCH-GW
User Specific
true
192.168.218.1
2000
2000
2000
5060
5060
5060
false
120
true
CP7905080003SCCP070409A
false010
1370242819-d90061cc-4e0f-4f5e-b558-3c9263535578
Russian_Russian_Federation
ru_RU
9.1.1.1000-1
windows-1251
Russian_Federation
Russian_Federation
50
http://192.168.21.2:8080/ccmcip/authenticate.jsp
http://192.168.21.2:8080/ccmcip/xmldirectory.jsp
http://192.168.21.2:8080/ccmcip/GetTelecasterHelpText.jsp
http://192.168.21.2:8080/ccmcip/getservicesmenu.jsp
96
false
cucm1
false
*81
*82
*83
*84
*85
Missed Calls
Application:Cisco/MissedCalls
Voicemail
Application:Cisco/Voicemail
Received Calls
Application:Cisco/ReceivedCalls
Placed Calls
Application:Cisco/PlacedCalls
Personal Directory
Application:Cisco/PersonalDirectory
Corporate Directory
Application:Cisco/CorporateDirectory
and here the dial-peer config
sochi-gw#show run | sec dial-peer
dial-peer voice 100 voip
description SOH_City_OUT
translation-profile outgoing SOH_OUT_9
destination-pattern 9T
session protocol sipv2
session target ipv4:93.190.xx.xx
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 101 voip
description SOH_MGMNDEF_OUT
destination-pattern 8T
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 102 voip
description SOCH_Emergency0x_OUT
destination-pattern 0[1-4]
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 103 voip
description SOCH_Emergency_OUT_9
destination-pattern 112
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 200 voip
description IN_2965873
translation-profile incoming SOH_IN_PSTN
incoming called-number 2965873
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 201 voip
description IN_6402
preference 1
destination-pattern 6402
session target ipv4:192.168.21.2:5060
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 202 voip
description IN_6402
preference 2
session target ipv4:192.168.21.3:5060
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 204 voip
description IN_6405
preference 2
destination-pattern 6405
codec g711ulaw
no vad
dial-peer voice 300 voip
description From_CUCM1and2
answer-address 2965873
dtmf-relay rtp-nte
codec g711ulaw
Could you please tell the command under the phone config in order to force the codec?
