IP Phone 8945 - Speed Dial don´t appear in the button
wilsonsant
Level 6
Level 6
Hi Guys,
I configured the speed dial on 8945, but, the numbers and label don´t appear in the button of IP Phone. When I press the Modify Button and try change the order (put the SD after the extension) I received the message: "Fixed Feature Buttons(s) cannot be changed. Please make sure the button number matches the relative positions in the button list".
Any have idea as solve this?
Wilson
Lando.Griffin
For the default 8945 Phone Button Template, some of the lines are fixed and can't be modified (though yeah, you would think you would be able to modify it on the fly under the Phone settings to create an individual template). What happens if you create a new Phone Button Template that's set the way you want, apply it to the phone, then enter your SD number/label?
