IP Phone Agent Service
tsperduto
Hi, we are looking at the IP Phone Agent service but I have not found any documentation that verifies if the service is compatible with a 7962 phone and if you can also use the extension mobility service on the same device.  Does anyone know of a document that addresses these two points?
Thank you,
Theresa
Rob Huffman
Hi Theresa,
The 7962 would be supported for both
For IPPA;
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_compatibility/matrix/crscomtx.pdf
For EM;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_5_1/ccmfeat/fsem.html
Cheers!
Rob
"When it comes to luck you make your own  "
- Springsteen
