IP Phone Call History and CUCM
gpsriramdc
Level 4
Level 4
Hi All!
I have no.of questions with respect to Phone Call history & Internal Provisioning. Kindly clarify
When IP Phone access the call history has there any interaction between CUCM and Phone to retrieve the call logs ?
where exactly call log resides ?
What is the exact functionalities Java Mid lets ( Application/Missedcall and Etc ) installed in the phone ? What it's make difference compare to external service provisioning ?
If the call logs are stored locally how normalization & globalization conversion applied to phone history ?
Thanks in Advance !!
Jaime Valencia
No, the phone logs are local to the phone, they're not in CUCM.
Anything you do, normalization/globalization/changes are done in CUCM, and the results delivered to the phone.
java
if this helps, please rate
Hi Jaime,
Thanks for your reply.  I have some more doubts.
How TFTP Server impacting the phone logs for SCCP Phones. If TFTP Server not associated in Phone configuration , it's not updating the call history.
Thanks in Advance
