IP phone change backgroud image on specific phone
Hi everyone. Requirements are : I need to change back. image on specific  8845  to specific image, all those phones will have same image and users cant change it.
I know I can do it with common device profile or on phone level , the question is what should I put on that field (in both methods): Background Image , should i put just the name of the image like
Background image: syn_wallpaper_12.png,  OR  should I put List.xml OR /Desktops/800x480x24/syn_wallpaper_12.png OR http://ip:6970/Desktops/800x480x24/syn_wallpaper_12.png ???
I couldn't find anything about it in Internet , on cisco docs....
I tried all of them none works , but if u tell how it should be at least i will know the problem somewhere else.
Anyone who has experience please share it ...
Thank you
6 Replies 6
Jaime Valencia
Just the name of the image: background.png
java
if this helps, please rate
so just the name of the picture which i want to use , nice .
And I guess if phone registered on one server but tftp server is on another server phone will use tftp which is 1st  on phone boot config, correct ?
Thank you
The phone will look at the TFTP it has configured for that image, just as it would manually.
java
tried as u suggested with just name on Common device profile with Background image : name.png, and then on phone, Background image : name.png, Phone personalization is enabled in both cases ,phone is c8845 .   Every time after changes did save-apply -reset , phone reboots with no changes :( . I tested with default pictures which CUCM has.
Any advice ?
http://docwiki.cisco.com/wiki/Endpoints_FAQ#How_can_I_bulk_change_the_background_image_for_all_my_endpoints.3F.3F
java
done fixed . it works now. did check-uncheck one more time and save -apply-reset and phones has image changed.
Thank you
