12-03-2013 03:22 AM - edited 03-16-2019 08:40 PM
we are having 2 call managers.
1 CCM 4.1
2 CUCM 8.6
IP phones are registered on both the call managers.Is it possible to communicate in between ip phones registered on two different call managers ?
Thanks And Regards
Pushpak
Solved! Go to Solution.
12-24-2013 08:10 AM
Do both cluster have the same FW version??
Did you configure the phone before registering it with CUCM???
Or at least enabled auto-reg??
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
12-26-2013 12:22 AM
Now i have removed cluster and trying to register phone with cucm 8.6 .( Added manually )
Phone model is 7906g and cucm is 8.6.
Still its showing unknown in cucm .
Do i need any device package for registering phone to CUCM.
Thanks And Regards
Pushpak
12-26-2013 03:00 AM
Hi Pushpak,
7906 is supported from CUCM 5.x and above.
Have u added the correct MAC addressof 7906 in CUCM ?
secondly what is the firmware u are using for 7906 ? are u facing problem with this model only or other mode phones are also not working.Did u start CCM service on call manager?
I do not think so u require any DEvice PAck.
regds,
aman
12-26-2013 03:13 AM
Hi Pushpak,
my mistake for Device PAcks
I have checked and found that u require DP for loads 9.3(1)SR1 and 9.3(1)Sr2
check the device compatibility matrix as per the phone firmware u are using.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/devpack_comp_mtx.html
regds,
aman
