IP Phone CP-7861 - SIP SERVER
JhaguilarR
Hello everyone, can I register the Cisco Unified IP Phone CP-7861, in a SIP server?
5 Replies 5
Jaime Valencia
Yes, the topic has been discussed many, many, many times at the forum, did you review any of those threads?
Start by finding out if your device is running enterprise FW or 3PCC FW to determine which threads would be applicable as the configuration is very different depending on which FW you use.
java
if this helps, please rate
Hello, the device is using the FW 3PCC, I have searched the forum but I find that they talk about an .xml file.
Then the phone has a config GUI in which you will need to fill in all the details so it registers to your PBX
java
Hello Jaime Valencia, a query, if the IP phone is in enterprise service mode, what is the procedure?
Provide all the configuration in the configuration files in the same .xml format as the phone would get them from CUCM.
java
