IP Phone DHCP
dtom
Currently, phones are on vlan 1 and getting a dhcp address.  I want to change this and move them to a new vlan - vlan 5.  I have done the following:
1) Setup the new scope on the dhcp server
2) Setup the vlan on the switche(s)
I reset the phone via CallManager and then add:
switchport voice vlan 5
to the port on the switch (just after I hit reset phone).  The phone shows unregistered in CallManager.  It appears that the phone does not get a new dhcp address on vlan 5.  If I remove switchport voice vlan 5 from the port on the switch, the phone comes back up with the same dhcp address (from vlan 1) and shows registered.  It is not a network (trunk) issue because I can add a static address from vlan 5 on the switch and access it from the router.  Am I missing something?  How can I get the phone to get the correct dhcp address (from vlan 5)?
Jaime Valencia
Have you configured the IP helper address??
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Jaime Valencia
java
java
The DHCP scope was not active.  Thanks.
