ip phone frimware upgrading
hi
I am using cucm 7.1. and ip phone is 7942g. the problem is the frimware of ip phone was not able to upgrade automaticaly.
and the ip phone was registering and unregistering continiously in cucm for remote site.
please tell me why it was registering and unregistering in cucm, frimware was the problem for this ?
i had tried to upgrade the
cmterm-7942_7962-sccp.9-2-1
frimware using tftp server but it was showing below message
ctlsep(mac).tlv not avilable
sep(mac).cnf.xml not avilable
xmldefault.cnf.xml not avilable
please tell me how to create the above files
                                            thanks.
Aaron Harrison
The files you listed should already be on your CUCM.
xmldefault.cnf.xml - a standard file
sep(mac).cnf.xml - should be created when you add the phone to the system
Since you don't see either of these files, do you have Option 150 set correctly on the DHCP server for the remote site? This should point to the CUCM publisher.
You can test the TFTP server from a windows machine like so:
tftp cucmipaddress get xmldefault.cnf.xml
If you get the file OK, your TFTP is OK. If it doesn't work from the remote site, perhaps you have TFTP blocked over the WAN. If it works from the remote site, then your phones may not be pointed at the ccm for option 150.
Aaron
Please rate helpful posts..
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
hi
thanks for your reply
but at first i am using cucm 4.3 at that time there is no problem of frimware upgrading and registering
while using 7.1 i am facing this problem. it keep on registring and unregistring
