IP Phone having problems with outgoing calls
Kaushik Ray
Hello
Can anybody please help me with the issue please?
I have a few IP Phones connected to the Call Manager and was working fine till yesterday. Both incoming and outgoing. Suddenly from this morning it is saying that whenever the IP Phones are picked up says "The Call Cannot be Completed as dialed" without even dialing a number. The incoming calls are fine no problem.
I checked the Call Manager status and it says it has been up for last 5 days.
No changes were made that could affect all outgoing calls? It is strange as to why it is getting the message immediately when picking up the handset and not even getting a dial tone.
Any advice please?
Thanks a lot in advance
nikshah
Look for a blank translation pattern created by anyone which has a no partition or which is in a partition in the CSS of the phone you are testing with.
Get me a ccm trace with the mac add of the phone 5 minutes before and after the call was made if you dont find any blank tp.
Hope this helps
Niket
Kindly rate all useful posts!!!
nikshah
Hope this helps
Niket
