IP phone how to communication with other site without voice gateway
tianwen.zhao
Hi guys,
    I am a totally beginner of Voice. Our company have Headquarter、Site1 and Site2
    Headquarter have call manager(CUCM) , site1 have voice gateway(C2900), and the IP Phone function of them is normally
   Now the question is that Site2  is a new site, and it doesn't have voice gateway(C2900). Site2 establish ipsec-vpn between  Headquarter and site1 , so site2 how to use the  IP Phone ?
Jaime Valencia
As long as the phones can communicate with CUCM, they can be registered. RTP is between endpoints, make sure proper routing is in place.
java
if this helps, please rate
6 Replies 6
Jaime Valencia
java
Thank you for your reply.
So , What 's the purpose of Site1's voice gateway(C2900)?
Most likely a PSTN GW or used for FXS, look at the HW specs and configuration to find out.
java
But I really don't understand what does FXS or HW specs mean......
Is there any relevant information to see ?
thanks
Hi, the Voice gateway at site 1 mostly being used for PSTN connectivity.
could you please check if there are any E1/T1 lines terminating at the site 1?
for site 2, as Jaime said, as long as there is connectivity with call manager and routing to the VGW's then you don't see any problem to phone registration and voice packet flows.
Really, you should start your reading on Cisco voice solutions. lots of documentation available on the public internet.
refer the SRND of Cisco call manager
you have to look at your call manager gateway configuration, dial plan and voice gateway itself to understand how the call routing works.
Please let us know if you have any specific queries or faults where we all can help you in a better way..
shalid
Thank you so much shalid, I think I have a lot of things to learn
