08-05-2011 09:46 AM - edited 03-16-2019 06:19 AM
I'm trying to import a phone into my call managers and keep getting an error. I have attached a screen shot of the error that is in the CM logs.
08-05-2011 09:47 AM
here is my Call Manager version that I'm running as well...
System version: 7.1.3.32900-4
08-05-2011 11:06 AM
Hi there,
Based on the error message it looks like the phone template you are importing does not match the device type that you are importing. If you upload the .csv file you're importing we can look at it.
HTH,
Chris
08-05-2011 11:15 AM
08-05-2011 12:00 PM
Template should be of same model as device profile, if you are building profile for 7962 phone, then make sure you select template of 7962.
